Archive 2008 · Renting a Calibrator
BigDan37
p.1 #1 · Renting a Calibrator
A monitor calibrator seems like a really useful tool but I have trouble swallowing the $200 price tag for something that I would use so rarely. Is there any sort of co-op or rental service available for someone like me who doesn't want to purchase one?
Aug 26, 2008 at 01:37 PM
Peano
p.1 #2 · Renting a Calibrator
You can get a Spyder2 Express for $60. I've been using one for a couple of years with excellent results.
Aug 26, 2008 at 01:45 PM
UCSB
p.1 #3 · Renting a Calibrator
My advice ... just buy one. You need the ability to calibrate as frequently as is required. Once you move to a color managed work environment, this struggle over the calibrator will seem silly to you.
Aug 26, 2008 at 01:52 PM
BigDan37
p.1 #4 · Renting a Calibrator
Thanks for link Peano. I guess $60 isn't that bad. You say have good results? Anyone know what I am getting for the extra $150 I would have to spend on a X-Rite EODIS2 Eye-One Display 2?
Aug 26, 2008 at 02:03 PM
BigDan37
p.1 #5 · Renting a Calibrator
Hmmm. I can see one issue. I use a dual monitor setup which the Spyder2 Express doesn't support. Bah.
Aug 26, 2008 at 02:08 PM
Alistair Watson
p.1 #6 · Renting a Calibrator
When I first started calibrating I used the Spyder 2, I couldn't get a decent result and I found the software truly awful, though it may have improved since. After a month I sold the Spyder 2 and bought an i1D2 and loved it, the Match software is stable, easy to use, and calibration was a breeze. Then I bought an NEC SpectraView panel and now use the SV software with the i1D2, calibration is now even easier but I still go with the adage of buy once and buy right, get the i1.
Aug 26, 2008 at 02:42 PM
redcrown
p.1 #7 · Renting a Calibrator
Look for a camera club in your local area. Such clubs usually meet on a monthly basis and share all kinds of info. In my local club, monitor calibrators get passed around like popcorn.
Aug 26, 2008 at 09:42 PM
Colin Key
p.1 #8 · Renting a Calibrator
I have recently bought the "Spyder 3 Elite" and am mega-impressed - well worth the money. My iMac 20" and Sony Vaio 17" laptop are at last displaying identical (and true) colours.
I keep the Spyder 3 permanently plugged into my iMac since it monitors ambient light and makes adjustments accordingly. I also have it set to check calibration levels every two weeks and inform me if re-calibration is necessary (it does drift).
Very easy to use, initial calibration takes approximately 6 minutes, a re-calibration check about 2 minutes, and fairly fool-proof.
Colin
Aug 27, 2008 at 08:10 AM
jerryrock
p.1 #9 · Renting a Calibrator
I agree with Colin's response, the Spyder3 Elite is the most versatile colorimeter on the market. It has the largest available sensor and seven color filters built in that make it the optimal calibration device for CRT, Projector, Laptops, LCD (both wide gamut and LED) displays.
Renting a colorimeter is not an option. Frequent re-calibration is necessary to maintain accuracy. Color management is not a not a one time event, it should become part of your normal workflow.
Edited on Aug 27, 2008 at 08:26 AM
teh_rebel
p.1 #10 · Renting a Calibrator
i had the spyder2express but have upgraded to the iDisplay2. Worth the cost IMO. Also, if u have friends or something that also needs calibration you can get them to split the cost and share it. Since the iDisplay2 (and perhaps spyder series as well) allows you to install it on multiple computers/laptops.
i still do have the spyder2express, if u just want a cheap solution to start off with. shoot me PM
Edited on Aug 27, 2008 at 09:13 AM
Aug 27, 2008 at 09:12 AM
torontonic
p.1 #11 · Renting a Calibrator
buy it.
calibration needs to be done every little while.
stay away from the Spyder3 Pro. Go for the elite. 3pro does not allow you to set manual luminance levels
Aug 27, 2008 at 09:17 AM
EA6B
p.1 #12 · Renting a Calibrator
I'm in a group of photographers that share a unit. We pooled our cash and made the purchase. We pass it around and get the unit every 6 weeks of so. We checked with the mfr. regarding licensing issues and there were none.
E
Aug 27, 2008 at 10:56 AM
BigDan37
p.1 #13 · Renting a Calibrator
Thanks for all the advice everyone. I went the cheap route with the spyder2 express. Since money is an issue we'll see if it meets my needs. If not, I'll sell it and save up for one of the higher end ones you have recommended.
Aug 27, 2008 at 11:48 PM
