figmented Offline Image Upload: On
p.1 #17 · Good resolution for printing 5x7s | |
I'm pretty familiar with imagesetters (press plate makers) - they expose film with a laser at 4800dpi, we regularly output at 300lpi (though I agree 120, 133 and 200 are used more with older equipment) the enemy with printing presses is dot gain, and that has to do with the substrate you are printing on, (gloss paper can hold an ink dot better then matte, it spreads) so that is where you get the lower lpi, because of ink spreading on lower end paper.
Also, most printers are switching over to stochastic dot patterns (similar to inkjet) instead of rossetes like normal CMYK process. which can yield even higher quality prints.
85 lpi is standard newspaper print, 200-300 for magazines
and then there is photo prints, where i dont know specifics, but i know its not normal dot patterns, and seems to 'run' together so you cant see dots even with a loupe (dye sublimation and/or heat)
