Archive 2008 · Nikon D40 Infrared conversion
MagicNikon
p.1 #1 · Nikon D40 Infrared conversion
Whew...what a rush. It worked, and I couldn't be happier. I'm still on a bit of a high after putting it all back together and finding that it actually worked!
My D40 IR filter arrived from LifePixel today. I have previously only had experience dissecting a Nikon D70. That was pretty easy and straightforward. There were only a few ribbon cables, and no de-soldering involved. I had some hesitation about doing my D40 the same way after discovering that there would be some soldering/de-soldering involved.
I debated about getting a D70s (I sold the first conversion I did, last year. Yes, I missed it enough, I wanted another IR camera). However, there is some inherent noise that creeps in even at low ISO's, so I wanted a model that would handle noise pretty well. D50's are scarce, so I decided on a tried and true D40. I actually have an unmodified D40 as my travel cam and backup to my D300. So, I picked up a used D40 last week, which has been waiting patiently for the arrival of the new LifePixel IR filter. I chose the normal filter...not one of the enhanced filters. I have had good experience using the original, and I like to do false color as well as B/W IR.
So...now on with the pics...
I assembled my screwdrivers, soldering iron, tweezers, and sensor cleaner and got to work.
http://jbsteinke.smugmug.com/photos/355289459_e6SzM-XL.jpg
http://jbsteinke.smugmug.com/photos/355289493_xYoV4-XL.jpg
remove all of the screws from the bottom and the bottom of the lens mount.
http://jbsteinke.smugmug.com/photos/355289532_j3mDx-XL.jpg
There is also a screw hidden in the battery compartment.
http://jbsteinke.smugmug.com/photos/355289552_5NDho-XL.jpg
Leave this intact. Do not remove anymore screws after removing the bottom plate.
http://jbsteinke.smugmug.com/photos/355289582_mhVZf-XL.jpg
Remove 6 more screws: Two from each side (SD slot area and USB side), and two on either side of the viewfinder. Gently pull the back away, and disconnect the LCD ribbon cable.
http://jbsteinke.smugmug.com/photos/355289689_SJ4aH-XL.jpg
The LCD cable is the one in the middle. Do not jerk the cable from its housing. Use a screwdriver, or sharp pointed object to gently flip the retention bar up, releasing the cable.
http://jbsteinke.smugmug.com/photos/355289731_Unrgn-XL.jpg
Seven ribbon cables to disconnect, and one large white cable, hidden under the PCB near the top four ribbon cables.
http://jbsteinke.smugmug.com/photos/355289779_6KxgV-XL.jpg
Now, before unscrewing the PCB from the camera, you must de-solder this pink wire. I touched the hot soldering iron to the blob, and it came free with no mess.
http://jbsteinke.smugmug.com/photos/355289870_q7gfa-XL.jpg
http://jbsteinke.smugmug.com/photos/355289912_3N8U9-XL.jpg
http://jbsteinke.smugmug.com/photos/355290059_4LWBz-XL.jpg
Everything is unseated, and the PCB is ready to be unscrewed to reveal....
http://jbsteinke.smugmug.com/photos/355289998_QEucw-XL.jpg
...the back of the sensor board. Almost there...hang tight....not too much farther!
http://jbsteinke.smugmug.com/photos/355290103_d4n7x-XL.jpg
Three screws hold this baby down. Unscrew them and pull it out. How many here have seen the backside of their shutter curtain?
http://jbsteinke.smugmug.com/photos/355290189_XubsD-XL.jpg
The heart of the image.
http://jbsteinke.smugmug.com/photos/355290226_xYrrf-XL.jpg
Two screws hold the spring loaded tension frame. Remove them, lift off the mount and gently lift off the black gasket.
http://jbsteinke.smugmug.com/photos/355290262_zXyKQ-XL.jpg
AntiAliasing filter removed (thats the aqua colored filter), the sensor is covered by a Pecpad. I took this moment to clean the dark InfraRed filter with Eclipse fluid and PecPad.
I hope it's clean...no way to know really, until tomorrow. We'll see
http://jbsteinke.smugmug.com/photos/355290289_FRP6s-XL.jpg
Gently set the InfraRed filter into the rubberized gasket seat over the sensor.
http://jbsteinke.smugmug.com/photos/355290320_Z5dLc-XL.jpg
Re-assemble the whole thing in reverse order. Lather. Rinse. Repeat as desired.
Some tips....
My big sausage fingers needed some delicate tweezers to re-seat the ribbon cables. I found that they re-seated rather easily and that the retention bars secured them just like it came from the factory. I do not recall the ribbon cables going back very smoothly in my D70 conversion....so this was a nice surprise.
Everything goes back together rather nicely, and certainly much quicker than the dis-assembly went. I popped in an SD card, a fresh battery, powered it up and fired off the shutter release. My hard work was rewarded with a functional menu screen and a decidedly pink picture!
Success!
http://jbsteinke.smugmug.com/photos/355290414_BJNBW-XL.jpg
Let's see how this baby handles tomorrow in the daylight! Stay tuned!
NOTE: I was lucky enough not to pop myself with the flash capacitor....be careful. I have no tips on how to avoid the flash capacitor, because I do not know where it is located on this camera. It wasn't evident to me, and I was lucky to not get a nasty shock. It probably goes without saying that you shouldn't try this if you have a weak heart or a pacemaker. Please be careful! The cap retains a charge despite the battery being removed.
I've upped my ISO, now up yours.
Edited on Aug 19, 2008 at 10:20 PM
Aug 19, 2008 at 10:10 PM
Quantum Man
p.1 #2 · Nikon D40 Infrared conversion
Very cool, looking forward to seeing the daylight pics.
Aug 19, 2008 at 10:39 PM
orthopod
p.1 #3 · Nikon D40 Infrared conversion
WOW, very cool, and nice picture follow along. I've been thinking about doing this as well...
Aug 19, 2008 at 11:13 PM
Justin Huffman
p.1 #4 · Nikon D40 Infrared conversion
sweet tutorial thanks for posting this. wish i would have snapped pics when i did 2 D1's... I dont think i could handle the soldering though ... well done
Aug 20, 2008 at 06:56 AM
bellyface
p.1 #5 · Nikon D40 Infrared conversion
this is awesome man!
Aug 20, 2008 at 03:38 PM
jbierling
p.1 #6 · Nikon D40 Infrared conversion
Nice!
Anyone have sort of a ranking of Nikon digital camera suitable for IR conversion?
Ie:
1. D70
2. D40
3. D40x
etc...
Thanks,
-Joel
Aug 20, 2008 at 10:32 PM
tc95
p.1 #7 · Nikon D40 Infrared conversion
I have three D100 I converted with the lifepixel filters....and have been very happy...very easy install...
D100 Standard IR strait from the camera
http://farm4.static.flickr.com/3070/2767466336_5db8a696c7.jpg?v=0
D100 Enhanced IR strait from the camera
http://farm4.static.flickr.com/3066/2766623941_3b0c3e9e62.jpg?v=0
A few other shots....I am still a work in progress with this IR stuff....but have been really happy with the D100 converstion...
http://farm3.static.flickr.com/2413/2766584597_365e44abb9.jpg?v=0
http://farm4.static.flickr.com/3046/2767430802_c6419d376d.jpg?v=0
http://farm4.static.flickr.com/3090/2766586099_9b13f90a78.jpg?v=0
http://farm4.static.flickr.com/3261/2766621825_9d9764c294.jpg?v=0
http://farm4.static.flickr.com/3115/2766629097_cdf7c3318b.jpg?v=0
You can go to this site to look at what they have instructions for right now....
http://www.lifepixel.com/IR.htm
Magicnikon sorry to post on your thread....just thought it was the right place...and sorry if I did not upload the pictures correctly...
TC
Edited on Aug 21, 2008 at 12:09 AM
Aug 21, 2008 at 12:02 AM
Slug69
p.1 #8 · Nikon D40 Infrared conversion
Outstanding step by step instructions, clear photos. You could have worked on the white balance though...
Aug 21, 2008 at 05:45 AM
nikt
p.1 #9 · Nikon D40 Infrared conversion
Great, great work.
Aug 21, 2008 at 07:12 AM
MagicNikon
p.1 #10 · Nikon D40 Infrared conversion
D70 is much easier than the D40. I assume D40x is the same as dismantilign the D40... but I don't actually know for sure.
jbierling wrote:
Nice!
Ie:
1. D70
2. D40
3. D40x
etc...
Thanks,
-Joel
Aug 21, 2008 at 07:10 PM
bellyface
p.1 #11 · Nikon D40 Infrared conversion
i've modded many nikons, I'd say the easiest is the D1 series, but the best thus far is the D200. No focus adjustments necessary. Actually, D50 and newer, I've noticed there wasn't a need to adjust the AF mirrors.
Aug 26, 2008 at 08:43 AM
