Moderated by: guardian
FM Forums | General Gear-talk | Join Image Upload
2 end
yankeefoxtrot
Image Upload: Off
p.1 #1 · Really Right Stuff
Looking into various ballheads (and maybe a camera plate at some point as well), and have a few questions about RRS - those of you who use their ballheads, were you happy with the purchase? Durable? They're local to me but unfortunately their business hours correspond exactly with my own work hours which just figures, and of course I'd like to hear from other photographers that use their gear in general. I like buying the best quality I can so that it lasts a long time and works well, and the RRS gear seems to have an excellent rep on that front.
Thinking of going with one of the midrange ones with the quick release clamp (though I'm still attempting to get through their extremely cumbersome website ) - I don't need a really heavy duty one as I plan to use it mostly for landscape and street stuff but I don't think the ultra lightweight one is going to be QUITE durable enough for what I want to do. Still shopping for legs, if that makes a difference, and the current setup weighs around 2 1/2 lbs (though there will be an upgrade to full frame in my future).
Thanks for your input.
Aug 08, 2008 at 05:08 AM
ozhop
Image Upload: Off
p.1 #2 · Really Right Stuff
We use RRS L-plates for three different cameras and have all three sizes of the ball heads with quick releases. For most stuff the BH-40 seems the best compromise for strength and weight. Every item is top quality and they are good people to deal with.
The L-plate for my wife's Pentax K10D is not perfect for portrait mode and using a cable release. Only about a third of the plate can sit on the ball head because of the positioning of the cable. They mentioned getting a Kirk spacer block to solve the problem. We have bought a wireless remote release instead.
Sometimes some items are slow to be available. Case in point was their B-150 macro focusing rail. I bought when they were changing the design and the order took a couple of months to be filled.
I have no hesitation in recommending their products. You can download their catalogue then just find what you want on their site.
I am taking my Gitzo carbon fibre legs and the BH-40 on this years trip to Patagonia and Antarctica and don't anticipate any problems with the gear.
Edited by ozhop on Aug 09, 2008 at 05:22 AM GMT
Edited on Aug 08, 2008 at 07:22 PM
Aug 08, 2008 at 07:39 AM
sjms
Buy and Sell: On
p.1 #3 · Really Right Stuff
on the positioning of the i/o ports on certain cameras (including my own) in reference to L plates. the L plate was designed to give your camera the ability to reposition quickly and within a certain margin of error accurately from horizontal to vertical. now as the camera designers put i/o in various locations on the camera body real estate. they introduce limitation to said setups using the L plate. both RRS and Kirk have done their best to surmount these challenges put forth by the manufacturers. there comes a time though where it just is not going to work the way all would like it too. the camera makers could care less about RRS/Kirk and their products. it is, as one would' say not their problem. they put the standard tripod hole in the bottom of the body. so there. both Kirk and RRS have different approaches for work arounds to make their products more usable.
you need to decide which one works best for you
Both RRS and Kirk are for the most part custom makers of products. this being said the issues of long lead times for certain specialized items as they are introduced and or again delays between stocking is attributed to their status as custom makers. Kirk is a full time machining facility where RRS is a design and prototyping setup. Kirk is meat and potatoes output. RRS is more design and integration oriented and in my opinion more innovative and advanced. again my opinion and is not debatable.
Durability: if you manage to break/destroy any of these makers items i strongly suggest you look over what it was attached to it because it most likely is totally obliterated. both products are built well beyond your cameras or tripods standards.
i have been using RRS products since 1991. they have evolved into a fully integrated yet for the most part open system based on the arca swiss clamp and plate assy. they offer the widest array of options for your use based on the said system
Edited by sjms on Aug 08, 2008 at 11:33 AM GMT
Edited on Aug 08, 2008 at 04:33 PM
Aug 08, 2008 at 12:09 PM
pturton
Image Upload: Off
p.1 #4 · Really Right Stuff
"happy with the purchase? Durable?"
Very happy with both my BH-40 and BH-55 heads, L-plates and lens plates. As mentioned, the RRS products are much stronger construction than most cameras.
Aug 08, 2008 at 12:31 PM
theMAGE
Image Upload: Off
p.1 #5 · Really Right Stuff
I ordered a L-bracket and a RRS-40 ball head last month. The fit&finish are excellent as well as the operation. That said, I preferred an Arca-Swiss Z1 to the RRS-40, so called them up to return the ballhead but keep the bracket. The return was very smooth. All in all, very professional.
Aug 08, 2008 at 01:05 PM
Lasse Eriksson
Image Upload: Off
p.1 #6 · Really Right Stuff
Both RRS ballheads and plates are very good. But I prefer the Markins ballheads
Aug 08, 2008 at 02:23 PM
tived
Image Upload: Off
p.1 #7 · Really Right Stuff
don't have the ballhead, but wished I did.
but I do have a fair bit of their gear and would recommend it anytime day or night.
Service is great, I have to thank Casey for, making sure I ordered everything and didn't double up on anything i didn't need. You don't get that many places...where they look up your old order and check that you have such and such part in your kit.
I have also purchased from them for a number of years now and the L-plate is gold, it is actually better on the Canon MkIII then it is on the original 1Ds.
I will be buying from them again...
Henrik
A Dane Down Under
Aug 08, 2008 at 02:42 PM
bshamilton
Image Upload: On
p.1 #8 · Really Right Stuff
I have the BH-55L and their L bracket. The lever quick-release makes it a breeze to switch from landscape to portrait orientation in a snap.
All very strong and stable, and also very smooth to operate. Highly recommend them!!
Barry
Aug 08, 2008 at 02:48 PM
yankeefoxtrot
Image Upload: Off
p.1 #9 · Really Right Stuff
This is what I was hoping to hear Looking through their catalog is like a kid in a candy store...
Aug 09, 2008 at 01:10 AM
sjms
Buy and Sell: On
p.1 #10 · Really Right Stuff
just got the L bracket delivered today for the D700. non grip.
Aug 09, 2008 at 02:58 AM
Alex Nail
Buy and Sell: On
p.1 #11 · Really Right Stuff
I am very happy with my BH-40 and quick release plate and I get the impression that it is a seriously durable ballhead, certainly the standard of manufacture is outstanding.
Alex
Aug 09, 2008 at 05:50 PM
dcains
Buy and Sell: On
p.1 #12 · Really Right Stuff
Not a big fan of their website, but I own several of their L-plates and ballheads. All top-notch gear, so I'm very pleased with it all.
Aug 09, 2008 at 09:43 PM
FSRamirez
Image Upload: Off
p.1 #13 · Really Right Stuff
I've been using the BH-40 LR with quick release plate and an RRS L plate on my camera for almost 3 years now with zero problems. I think they do an incredible job and the staff is friendly and knowledgeable.
Aug 10, 2008 at 12:25 AM
Genes Home
Image Upload: Off
p.1 #14 · Really Right Stuff
I have only good things to say about RSS equipment.
All of their stuff is built well beyond any standard you would expect to see.
Ballheads are excellent. I have both the quick release and the normal plates and really can't decide which I like best. Its probably psychological, but I use the long base normal plate for my telephoto lens on my heavy tripod, and the quick release plate for normal and wide angle stuff on my lighter "walk around" tripod. I replaced the feet on my 70-200 and 300 f/4 with the RSS feet, and still think it was a smart move.
I have no problems highly recommending RSS to you.
Aug 10, 2008 at 02:51 PM
luke.price
Image Upload: On
p.1 #15 · Really Right Stuff
another vote for RRS! Great kit
Luke
Sep 25, 2008 at 11:44 PM
Michael Nelson
Image Upload: Off
p.1 #16 · Really Right Stuff
The RRS L-plate I have on my Canon 40D has a slot on the bottom. If you loosen the screw that mounts it to the body, you can slide it to the left creating room for a remote cable release to be used with the L bracket in the vertical position. Kind of a PITA to have to do that, but it does work.
I also have their BH-40 ball head and like it a lot. I used to have a Markins M10 and like the BH-40 better.
Sep 25, 2008 at 11:54 PM
dcains
Buy and Sell: On
p.1 #17 · Really Right Stuff
The one non-RRS (Kirk) L-bracket I own is for my 40D, because of what Michael mentions above. The Kirk doesn't require any fiddling to use a remote cable.
Sep 26, 2008 at 01:07 AM
Todd Warnke
Buy and Sell: On
p.1 #18 · Really Right Stuff
I have an RRS L-plate for my D300 and love it. I also have a pano rail from RRS and it too is a joy to use (as well as to fondle ... don't tell my wife). As for ballheads, I found the BH-40 nice when I used a friends, but I prefer the Markins Q3. That said, if I had the RRS I don't think I'd sell it for the Markins as they are both quality kit. BTW, I also have a replacement foot from Kirk for my 70-200VR and the stuff from all three companies work well together.
Peace,
Todd
Sep 26, 2008 at 02:17 AM
Fred Amico
Image Upload: Off
p.1 #19 · Really Right Stuff
Same here. Using a Markins ball head and a RRS L-plate. The plate is very well made, and I wouldn't hesitate to recommend it.
Sep 26, 2008 at 04:37 AM
GeorgeK-NJ
Image Upload: On
p.1 #20 · Really Right Stuff
"RRS" just "SUCKS" The money right out of your wallet that is. Some of the best machined stuff around, great CS to boot. One year I opted not to get a lens or 2 and picked up a bunch of RRS stuff. Things like a Ballhead, Plates, Leveler Clamps, Flash Brackets and Micro-Rail. About $2K then I was done. The only thing I got rid of was the Micro-rail and I got almost full value here at B&S. Really love their stuff.
Sep 26, 2008 at 12:50 PM
Cableaddict
Image Upload: On
p.1 #21 · Really Right Stuff
George raises perhaps the best point about RRS gear- The resale value here & on fleabay is practical full retail. You just can't get hurt badly, even if you decide to go a different direction later.
As far as ballheads, I need a new one, and am personally leaning towards the Markins.
I also want to look further into the brand-new Gitzo heads. They look VERY promising.
Edited on Sep 28, 2008 at 12:44 PM · View previous versions
Sep 26, 2008 at 02:46 PM
molson
Image Upload: On
p.1 #22 · Really Right Stuff
I recently sold my RRS BH-40 and BH-55 ball heads. There are better products out there for less money.
Sep 26, 2008 at 06:46 PM
forestmage
Image Upload: On
p.1 #23 · Really Right Stuff
I've been using their BH-25 with quick release plate on my Gitzo 1541T for travel this summer and the combo has been great. Very lightweight, yet sturdy.
Sep 26, 2008 at 06:54 PM
Mike Ganz
Image Upload: On
p.1 #24 · Really Right Stuff
You won't go wrong with RRS or for that matter Kirk. I'm using two RRS L-brackets and a Kirk L-bracket. The Kirk is fully compatible with the RRS lever clamp, so no problems there. In addition to the L-brackets and lever clamp, I'm using a lot of other RRS gear, but opted for the Markins M10 ballhead.
Sep 26, 2008 at 06:59 PM
garyroach
Image Upload: On
p.1 #25 · Really Right Stuff
Gotta love RRS.
Sep 27, 2008 at 08:05 PM
2 end
Lost password?
