Cableaddict Online Image Upload: On
p.1 #3 · Separating misthreaded filter | |
If one is thicker than the other, or (unlikely) if one is made out of a different plastic compound than the other, you may have success with either extreme heat or extreme cold. -The idea being that one would expand or contract more than the other.
Obviously, you'd need to figure out how to apply the heat / cold to just the plastic. Don't put the whole lens in an oven. Maybe a hair dryer aimed sideways? For the cold, maybe a flat piece of dry ice applied directly?
I'd also spray some kind of industial lube in there, as Geno mentions. Something really thin, like the above-mentioned "break free" or Tri-Flow. In fact, I'd try the lube first, with no heat/cold. Try-Flow stuff is amazing. "Break free" CL-5 is also really good stuff, but I think Tri-flow is a tad thinner. You may need all the penetration you can get.
Either one, though, but I don't recommend machine oil. It's too thick & won't penetrate as well. I've experimented with lots of lubricants (ahem) and Tri-Flow is far & away the best non-corrosive spray for tight, stuck parts.
I'm not so sure about using those "rubber loop" wrenches. I first thought to agree with Genes for that idea. Those wrenches do give a lot of power and a good grip. However, they don't really apply even pressure all around. Most of the pressure is on the leading edge, due to the band being pliable. You might be better able to keep even pressure with your hand. Hard to say.
Good luck.
Edited on Aug 07, 2008 at 10:41 AM
