phil hawkins Offline Image Upload: On
p.1 #4 · cant figure out this working space stuff | |
The browser has no bearing on this issue.
1) BEFORE you open an image, go to Edit>Color Settings>Working Space, make sure it's set to sRGB, again, BEFORE you open your image. If you shoot in sRGB (?) then when you open the image you will get no warning. If the image is shot Adobe RGB you'll get a warning notice, say yes.
2) File>Save for web and devices> and proceed from there. Bet sure the dialoque box is set for "2-up" so you can see the original with the resulting jpg to be sure they match.
This should solve your problem.
Edited on Aug 04, 2008 at 11:22 PM
