Moderated by: guardian
FM Forums | PRO digital corner | Join Image Upload
haijak
Image Upload: Off
p.1 #1 · CD Proofing Software
I'm looking for software that will auto run on a proof CD, and allow the user to browse photos, taking down image numbers for album selection.
I can navigate a CD of JPGs very well on my own, but I have run into less computer savvy, who don't know you even can browse the files on a CD.
I tried making my own with PowerPoint, (presentations with 450+ pages take to long to load) and automated websites. (can't autorun HTML)
I can't imagine I'm the first who want's to do this. Has anyone else figured it out?
Jul 18, 2008 at 02:25 PM
Silentlight
Image Upload: Off
p.1 #2 · CD Proofing Software
I don't have it here at work to try, but can't the lightroom's flash-based web gallery option do this?
Jul 18, 2008 at 08:49 PM
Marcel VanEerd
Image Upload: On
p.1 #3 · CD Proofing Software
Why not make an auto-run CD, with photo numbers shown on the image. It should be simple enough to write down numbers, or isn't that what you want?
For example.. http://www.softwarepatch.com/tips/autorun.html
haijak
Image Upload: Off
p.1 #4 · CD Proofing Software
Thanks guys.
I actually had a Lightroom Flash Gallery created already. It was the first thing I though of.
But I ran into the problem that windows won't autorun a document, only programs.
All the solutions i found were these extra programs that tried to be more complicated then they needed to be.
Marcel your solution to that is a fantastic 4 line batch file that works flawlessly. Thanks.
Jul 18, 2008 at 08:58 PM
Marcel VanEerd
Image Upload: On
p.1 #5 · CD Proofing Software
your welcome!
Jul 19, 2008 at 02:31 AM
donrisi
Image Upload: Off
p.1 #6 · CD Proofing Software
So far, everyone I've recommended this program to has spurned me, but here goes again.
ACDSee Pro has the ability to create slide shows (with music if you want! ) in either Windows screensaver (SCR) format or as EXE files. Either can be made to autorun off a CD-ROM. The SCR has advantages and drawbacks -- wiggle the mouse, and it stops. Restart means starting over from the beginning. The EXE files include a small control bar at the top which disappears on its own, then reappears when you run your mouse up there (you might include instructions as your first slide).
If you don't like the idea of having your clients pause the slide show on their own, ACDSee allows you to create a slide show that requires manual advance (hitting the space bar, or the down arrow, or something like that), but that negates the ability to include music.
You can also include either header text or footer text (or both). The text is completely customizable is every way, and can be anything from your contact & ordering info to file names (personally, I'd do the former as the header, and the latter as the footer, but that's me). You can insert any metadata, or darn near anything else.
Making it autorun is easy. You'll need a file called autorun.inf . Open Notepad, and copy this code (assuming you've created an EXE file):
[Autorun]
OPEN=yourfile.exe
Make sure you change the file name from "yourfile.exe" to whatever you named your slideshow file. Don't use anything except Notepad for this.
Save the file as "autorun.inf" (without the quotes, of course), and burn that along with your EXE slideshow to the CD. Make sure to test the whole thing on a different computer than the one you created it on, just to make sure. (Note: if you save a copy of the autorun.inf on your computer's hard drive, change the name or it will try to run every time you boot your computer )
That's how I create proof slideshows on CD. Good luck with your project.
Don
Edited on Jul 20, 2008 at 02:58 PM
donrisi
Image Upload: Off
p.1 #7 · CD Proofing Software
Marcel,
Your solution is pretty slick. Excellent!
Don
Jul 20, 2008 at 03:02 PM
Lost password?
