badmash12 Offline Image Upload: Off
paulhodson wrote:
Welcome. It is overexposed - if you open the image in Photoshop and open the Levels dialogue you can see that the graph is too far to the right. If you hold down the "Alt" key and click on the right hand arrow under the graph you can see that the red channel is the problem.
If yo shot Raw you could probably improve it in the conversion - if not - now's the time to move over to it as although it will add to your post processing learning curve it makes it easier to recover from errors.
Strong colors like reds and yellows often give this problem.
Hope this helps.
In this image it has made the tractor take on quite a painterly look!
Paul,
That does help, thank you very much, any tips on how to not under expose or correct it in PP... I haven't shot in RAW yet.. just JPGs
bm
