PhillipAnthony Offline Image Upload: On
SmugMug Pro User??? | |
MichaelKirk wrote:
Phillip,
Correct, I make my conversion from ProPhoto colorspace to sRBG at export in Lightroom. The Export Plugin (which I use for SM and Flickr) give you the option of which colorspace you want to use at export. This is done in bulk so however many images I am exporting will all be converted when exported.
If your not using Lightroom - you should seriously take a look at it - it was a hugh time saver for me. I shhot mostly sports so I am uploading and PP 1000+ images per event.
Michael
Michael,
Thanks again for the great info.
To get started, I use Lightroom A LOT! Ha, that's really an understatement because I practically live in LR, but I've NEVER used it to convert my DNGs to sRGB format. Live and learn, I guess.
Poking around in the export module of LR I did see the sRGB export option, so I'm good to go there. The issue I have at the moment is that I've already tweaked 200+ images in LR and converted them all to Hi-Res JPEGs. I'm now wondering if I can, using LR, export them as sRGB JPEGs and not lose any resolution in the process.
The real question banging about in my head is that there will probably not be a single person that will purchase a photo from this event. To be completely honest here, I really do not care because I was already paid (well) for this event and am simply following out my clients wishes to upload these images so that her clients can see these photos and purchase any if they wish to. Because of my inexperience with this - the converting to sRGB, this is turning into more work that I anticipated. Had I known about this early on, things would be a bit different. Regardless, I can get through this in a few hours of work. If I can indeed convert my already tweaked JPEGs, I'll be one happy dude.
I'd better get to it.
I appreciate your help and time.
Phillip
