Archive 2008 · Shooting into the light
rashley
p.1 #1 · Shooting into the light
Early Saturday (May 31) I am off to a Balloon Festival. I took this shot last year and need to understand what I can try to avoid more of the same. All advice photographic welcome...I appreciate Photoshop is a great tool, but only if the RAW file is decent so in camera advice first. Thanks.
Edited on May 29, 2008 at 12:30 PM
May 29, 2008 at 12:29 PM
Bob Jarman
p.1 #2 · Shooting into the light
Hmm, Exif says you used a D200 - if you still have that, and I'm not familiar with Canon, at a minimum set it for spot metering and meter on a balloon.
Shoot RAW!
Better yet, using a tripod, rip off a series of bracketed shots to get a range of under - proper - over exposed images. You should be able to use one, or sandwich two of those in pp'ing to render the full range of colors.
The image you posted was shot using
# Max Aperture = F3.48
# Metering Mode = center weighted average (2)
# Light Source / White Balance = unknown (0)
and probably focused at some point in the sky (since the sky is properly exposed). Be sure to check the histogram to make sure you've not clipped blacks or whites (at least too much).
Good luck - let us see your results...
Bob
Edited on May 29, 2008 at 12:44 PM
May 29, 2008 at 12:43 PM
rashley
p.1 #3 · Shooting into the light
Thanks. I use a Nikon D200 with D200 zoom.
May 29, 2008 at 12:53 PM
Bob Jarman
p.1 #4 · Shooting into the light
Nicely done Scott,
BTW, is the framing via FM?
Bob
May 29, 2008 at 07:19 PM
sbeme
p.1 #5 · Shooting into the light
Rashley,
Let me know if you want me to remove the re-work.
Bob, new features apparently added to FM. This is the classic black frame option. There are about a 10-20 frames you can now place around the images. I guess a benefit of the image upload service.
Scott G
May 29, 2008 at 07:45 PM
Icarian
p.1 #6 · Shooting into the light
very nicely done! congrats
Jun 01, 2008 at 02:22 AM
sbeme
p.1 #7 · Shooting into the light
Very nice series.
Came ot great! 2 and 3 are my favorites, but they all are captured well.
Scott G
Jun 01, 2008 at 04:01 AM
Bob Jarman
p.1 #8 · Shooting into the light
I wish I could follow my and others advice and get this kind of result
Great series!
Thanks for sharing,
Bob
Edited on Jun 01, 2008 at 06:55 AM
Jun 01, 2008 at 06:54 AM
jehanzeb
p.1 #9 · Shooting into the light
Nicely done.
Jehanzeb
Jun 02, 2008 at 03:18 AM
Matt Cope
p.1 #10 · Shooting into the light
That's quite an improvement, good work
Jun 02, 2008 at 06:52 AM
Scott Stoness
p.1 #11 · Shooting into the light
You have nice pictures in series - my favorites are the close crops. On the first I don't think you can get this kind of shot with the light you have. Another hour later with a low sun catching the balloons is needed otherwise there is too much difference between sky and balloon and one or the other will look bad.
So my advice is plan the lighting - early morning is best. And avoid bright skies. But I have never tried this before.
Jun 02, 2008 at 10:24 PM
rashley
p.1 #12 · Shooting into the light
Thanks to each of you for your advice and encouragement...One of my balloon shots (none of the above) made the finals in the WA. It was the bracketing that made it possible. And let's hear it for a good, light weight tripod. This forum works!
Jun 05, 2008 at 07:12 PM
sbeme
p.1 #13 · Shooting into the light
Congrats!
Thanks for the followup.
Scott G
Jun 06, 2008 at 01:45 AM
