Moderated by: guardian
FM Forums | Nikon-mount SLRs | Join Image Upload
Chris Dees
Image Upload: On
D300 filenumbering
I want to set the filenumber to the same number as the numbers shot with the camera. Is this possible? I can't find this in the manual. Can anybody help me with this?
Thanks.
May 16, 2008 at 06:26 PM
jamach
Image Upload: Off
D300 filenumbering
glad to help but could you restate the question, does not make sense to me
thanks
- Joe
May 16, 2008 at 06:27 PM
Chris Dees
Image Upload: On
D300 filenumbering
Excuse me for my English, I'll try it with an example
Filenumer is 2457 and numbers shot with the camera is 1445.
I want to set the filenumber to 1445.
May 16, 2008 at 06:36 PM
jamach
Image Upload: Off
D300 filenumbering
wow, how did the filenumber get to be 2457?
I set my camera to start at 0 after every format of the cf card, but that has problems too.
Also, I renumber my files using ViewNX, but other programs such as CS3 can batch a renumbering.
How about renaming the file? You can rename it just about anything you want, including 1445.jpg or 1445.nef, or 1445.tif
Do you have just one file to renumber?
Are you trying to set the counter number on the camera to 2457?
- Joe
May 16, 2008 at 06:41 PM
binary visions
Image Upload: Off
D300 filenumbering
You have to do it by manually renaming the files. There is no way to tell the D300 to "sync" with the number of shots taken by the camera.
May 16, 2008 at 06:48 PM
Chris Dees
Image Upload: On
D300 filenumbering
- Joe
I used a CF card from my D3 with files on it.The filenumber system takes the highest.
How do you set the camera at 0?
If it's at zero I can try to fool it to 1445
I don't want to change the counter number, just the other way around.
May 16, 2008 at 06:59 PM
jamach
Image Upload: Off
D300 filenumbering
I am sure one of the D3 people can help you, I am a D300 guy
good luck!
- Joe
May 16, 2008 at 07:01 PM
Chris Dees
Image Upload: On
D300 filenumbering
The "problem" is with the D300 (not the D3).
May 16, 2008 at 07:03 PM
HerbChong
Image Upload: On
D300 filenumbering
you tell the D300 to start renumbering from 0 every time the card changes. put in an empty card. take one picture. then you put in a card with the file with the number that you last used, set the camera to remember the last number used, and take one picture. this is another reason not to share cards across cameras without formatting first.
Herb...
May 16, 2008 at 07:09 PM
jamach
Image Upload: Off
D300 filenumbering
section d4:file number sequence
also page 321 of D3 user guide
also, it sounds like the cf card needs to be formatted before use in the d300, no?
I will bail out now, because someone with a d3 and a d300 should not be having these problems. I would suggest a bowl of cereal and cartoons in the afternoon, then cocktail hour at 5. I usually do my humor in the evenings with the Colbert Report and Daily Show With Jon Stewart, then Futurama.
- Joe
May 16, 2008 at 07:14 PM
Chris Dees
Image Upload: On
D300 filenumbering
Thanks Herb, that's what I'm looking for!
But, it sounds a little bit silly, I can find it in the menu's/manual.
I know this should be possible (at least on my Canon's )
May 16, 2008 at 07:16 PM
Chris Dees
Image Upload: On
D300 filenumbering
Finally found it. It's d6 on the D300.
Thanks for helping out.
May 16, 2008 at 07:19 PM
Lost password?
