Archive 2008 · 40D and 85 f1.2 battery drain
RCicala
p.1 #1 · 40D and 85 f1.2 battery drain
I have a weird problem and wonder if anyone has any input. A customer shooting a 40D found his battery drained in about 60 shots when he started shooting with an 85 f1.2. His camera doesn't exhibit the problem with any other lens so the obvious assumption was something about the 85 f1.2 which was exchanged for new 85 f1.2. The new one also drains his 40D in 40-50 shots. He gets hundreds of shots with a 24-105 f4 IS, and the problem has repeated with a different battery.
Any help / ideas would be most appreciated.
May 10, 2008 at 09:47 PM
Zara
p.1 #2 · 40D and 85 f1.2 battery drain
I remember someone on POTN reporting this problem (Username wimg).
Personally, I shoot this combo (40D/85L) frequently and have not seen anything similar. I've gotten well into the hundreds of photos on a battery charge without dismounting the 85L, though a single session was never over 100 shots.
Edited on May 10, 2008 at 10:01 PM
May 10, 2008 at 09:57 PM
njjuliano
p.1 #3 · 40D and 85 f1.2 battery drain
I had this issue, and posted about it here. I tried the lens with other bodies, no drain. I tried the body with other lenses, no drain. I tried with grip, without. Just to be clear, when I take the battery back into the cam, it will resume to the full capacity, and will drain again in a matter of shots. Cgardner mentioned something about its a safety characteristic for over/under current, or something to that effect.
I sent in the lens, and they changed some circuitry. But still exhibited the drain.
I sent the 40d next, and they changed something there as well. I have no more issues with the pair.
I would send it in, and have them check it out.
May 11, 2008 at 09:58 PM
mgkaplan
p.1 #4 · 40D and 85 f1.2 battery drain
I used a 40D paired with an 85 1.2 to shoot an event recently. I shot more than 500 frames and still had battery power remaining.
May 12, 2008 at 09:30 AM
pawlowski6132
p.1 #5 · 40D and 85 f1.2 battery drain
For those of you having good luck with battery life, were you shooting in AF Servo mode?
Jun 16, 2008 at 06:24 PM
maver
p.1 #6 · 40D and 85 f1.2 battery drain
More and more people are reporting this issue. Found the following threads:
https://www.fredmiranda.com/forum/topic/642304/0
http://forums.dpreview.com/forums/readflat.asp?forum=1019&message=29732915&q=40d+85+battery&qf=m
https://www.fredmiranda.com/forum/topic/661416/0#5900074
https://www.fredmiranda.com/forum/topic/645509/0?keyword=40d,85,battery#5735622
http://forums.dpreview.com/forums/readflat.asp?forum=1019&message=29547126&q=40d+85+battery&qf=m
https://www.fredmiranda.com/forum/topic/615284/0#5470157
http://forums.dpreview.com/forums/readflat.asp?forum=1019&message=29510282&q=40d+85+battery&qf=m
http://photography-on-the.net/forum/showthread.php?t=529551
http://forums.dpreview.com/forums/readflat.asp?forum=1029&message=28292088&changemode=1
https://www.fredmiranda.com/forum/topic/695699/0#6256486
Oct 22, 2008 at 12:13 PM
maver
p.1 #7 · 40D and 85 f1.2 battery drain
SOLVED!
Canon has released firmware version 1.1.1 for the 40D which is said to solve the battery drain issue...
Jan 22, 2009 at 04:01 PM
