Scott Stoness Offline Image Upload: On
how about these | |
dalgin wrote:
This is awesome. Thank you very much for all your comments. They are very constructive.
The reason I went to F29 is it was too light outside and I knew I had to slow down the shutter speed.
In times when you know you need F8 and 1/10~1/3 shutter speed for silky water and there is too much light, and if your iso is already down to 100, what else can you do?
Again, thank you very much for all your comments.
If you have the cokin filter holder, you add the polarizer (causes less light ), add nuetral density filter (adds anywhere from 1 to 4 stops depending on which one you add). A nd filter is either plastic or glass and dark grey - all it does is cause the need for more time exposure.
