Canon 10D Offline Buy and Sell: On
shooting baseball pics on cloudy days | |
picchick wrote:
should i use AWB, set it on cloud, shade or customize my own WB?
Ideally, you would want to do custom WB for most accurate color reproduction. If you don't know how to do custom WB, I would suggest to just shoot RAW and use the presets (cloudy, sunny, shade, etc.) to start and then play with the color temperature settings (either presets or custom values) during post processing to get a feel of how color temperature changes. Once you have learned and get used to how color temperature changes, you shouldn't have problem choosing the right color temperature in the future. Avoid using AWB if you shoot jpeg because you never know what color temperature is chosen by the camera during AWB, and it will be a pain if you need to adjust WB during post processing because you don't know what color temperature has been used; but if you have used 6500K, for instance, instead of AWB, that will give you at least an idea or as a reference point of where to start in adjusting color temperature if needed.
Hope this help a little
