Found this shed about 20 miles from Yakima, Washington. The owner had around four hundred vintage car and truck bodies on his property. Thanks for looking. -Art
Did an hdr merge of -2 / 0 / +2 ev exposures (taken from a single raw image); added a very small amount of tone mapping; exported to PS; converted to b/w; [skipped the Artistic > poster edges]; sharpened using the high pass filter approach; did minor contrast and brightness adjustments. This left the entire image looking similar to the bright center area, so I darkened the outer edges and corners to direct the viewers gaze on the image and provide the feeling of depth, then added the border. As you can now see, the fundamental recipe is like Alan’s… I simply find that the details vary depending upon the specific image in question.
