Craig B. Offline Upload & Sell: Off
Recently purchased a 24" iMac that came with 1 gig of memory. Last Friday I went to the MacMall outlet and bought two 2 gig chips to upgrade to 4 gigs of RAM. Installed them and when I turned the computer on it would not start up all the way and made a beeping sound. The manual said if that happens to turn it off because either the memory is not compatible or it is not installed properly.
So opened it up and discovered that it had not been shoved in far enough to make the proper connection, so fixed that and it has been fine until last night.
Saw that Nikon had an upgrade for Capture NX and proceeded to download. For those who don't know, Nikon software, especially Capture NX can be very slow and buggy and prone to problems. Even more so with the Leopard OSX.
Well it started loading real fast and was almost finished when the computer locked up and I could not get it to quit the program so had to hold the power button down for the iMac to shut down.
So here is the weird thing, when it was turned back on it would not load up but made the distinctive beeping sound of memory not compatible or installed incorrectly. So I took the memory out and placed it back in again to no avail, tried all the different ways to restart the computer that Apple suggests, and finally switched the memory cards back to what originally came with it. Then it worked just fine again.
Downloaded the TechTool cd that comes with the Apple Care Protection Plan and did a diagnostic and everything came up roses.
If I call Apple they will probably say something to the effect that I did not buy the memory they provide and I am on my own. Don't know how MacMall is with returns for memory so figure I'd ask here first.
Could the bad download somehow have fried the memory, or was that a coincidence that the memory happened to go bad in the middle of a download? Anyone ever have memory go bad like that? Is it a problem in the iMac, or have you got any other ideas?
Thanks
