Pantel Offline Upload & Sell: Off
I know it can happen, because it happened to me while using the CopperHill Method. I've used this many many times with no problems and most the time the static sensor brush does the job, but occasionally the sensor needs a wet cleaning. I've always been careful and cautious while doing this, but the last time I did, there was something on the sensor I did not see before the wet cleaning. My procedure is always in this order, blaster a few good blasts while holding camera face down and then checking image, if spots then static brush and check, repeating if spots persist and if it's necessary, wet clean and check. Sometimes it takes a few cleanings. I ended up sending it to Canon because I couldn't live with a damaged camera. Canon's procedure is to email you the estimate then you pay by phone or online. In this case it was $614 worth of education. Now I'm considering ordering the sensor scope or better yet, the camera shop I visit on occasion, will clean the sensor while you wait always checking the sensor until it's clean. Hope this will help someone to learn from my experience.
