Wedding Resource List
       2       3       end
Archive 2008 · Anyone using 16GB CFs?
asimsoofi
p.1 #1 · Anyone using 16GB CFs?
After using mostly 2GB cards for a couple of years now, I'm getting tired of carrying so many cards. Always kept thinking about failures...but I've never had one yet with these cards. They just keep on ticking.
I'm dropping some money on 8 and 16 GB cards, with some reservation about my eggs.
Anyone shooting 16GB cards?
Apr 09, 2008 at 12:08 PM
DavidWEGS
[X]
p.1 #2 · Anyone using 16GB CFs?
Yup 6 of them plus several 8's a backups
Apr 09, 2008 at 12:50 PM
RedWhiteandRed
p.1 #3 · Anyone using 16GB CFs?
Yes, several of the cheapest ones I can get. Almost using the cards as a backup for some clients.
THe real cheap ones are now something like $70 each.
Apr 09, 2008 at 01:03 PM
DB
p.1 #4 · Anyone using 16GB CFs?
Sounds like a great idea! I'll add that I *did* have one complete, irrepairable failure with a 2GB card while I was in Haiti. Not a huge deal, but we did lose a lot of great photos that day. So I am having a hard time moving above a 4GB card
Apr 09, 2008 at 01:48 PM
chromalogy
p.1 #5 · Anyone using 16GB CFs?
I'm shooting with 8Gb and 16Gb cards. However, in order to avoid loosing all my images in case of failure, I don't fill them up. I see 8Gb and 16Gb cards just like a 4Gb card but with added "overhead" which I may need in particular situation where changing a card would mean potentially losing images.
Apr 09, 2008 at 02:05 PM
curryphoto
p.1 #6 · Anyone using 16GB CFs?
I get paronid about putting all my images on one card. I have an 8 , but prefer ot use the 2's and 4's. It only takes a few seconds to change a card. Thomas
Edited on Apr 09, 2008 at 03:20 PM
Apr 09, 2008 at 03:19 PM
asimsoofi
p.1 #7 · Anyone using 16GB CFs?
I'm more paranoid juggling and losing the card itself during a wedding.
Thank goodness haven't had corruption or loss happen so far.
Edited on Apr 09, 2008 at 03:30 PM
Apr 09, 2008 at 03:29 PM
tassiesnapper
p.1 #8 · Anyone using 16GB CFs?
Is there anyway to test the condition of the cards, so as to predict when they might be starting to fail or deterioate? or do they just go *bang* and they are dead?
Apr 09, 2008 at 04:29 PM
bacilonur
p.1 #9 · Anyone using 16GB CFs?
They just go *bang*, though frequently it's from a physical bang, whether being dropped or by being shorted somehow. I keep 16GB SD's in my 1DS/1D, works great in a pinch. My CFs are 4 and 8.
Apr 09, 2008 at 05:22 PM
Mike C.
p.1 #10 · Anyone using 16GB CFs?
Have any of you used 16gb on a wedding?, and they only need the fail once on a wedding and your reputation will have gone in a day.
Mike
Apr 09, 2008 at 05:43 PM
scott shoemake
p.1 #11 · Anyone using 16GB CFs?
yeah, i think 4s and 8s are safe for raw shooters.
Apr 09, 2008 at 05:54 PM
asimsoofi
p.1 #12 · Anyone using 16GB CFs?
Mike, I understand your point, but it's similar to hard drives historically.
1998 - My computer had a 13 GB hard drive.
2008 - My computer has a 250 GB hard drive.
We're progressing. It won't be long until a 2 GB will be equivalant to what a 256MB CF card is now.
Apr 09, 2008 at 05:57 PM
SLD
p.1 #13 · Anyone using 16GB CFs?
Comparing one 16G card and two 8G or four 4G cards, the card failure rate is much much less than the rates you lost your cards or physically damage the cards....
And you do have the very high rate to recover your failed card if it happened. But if your cards were lost or physically damaged, you have very few chance to get the data back...
Edited on Apr 09, 2008 at 07:00 PM
Apr 09, 2008 at 06:57 PM
FoxyLoxy
[X]
p.1 #14 · Anyone using 16GB CFs?
I have not yet tried the larger capacity cards, but I tend to agree with lidesun- that the human error rate is most likely much higher than mechanical errors.
Apr 09, 2008 at 07:07 PM
cordellwillis
p.1 #15 · Anyone using 16GB CFs?
Please provide stats info.
Thanks
Apr 09, 2008 at 08:08 PM
Mike Mahoney
p.1 #16 · Anyone using 16GB CFs?
I'm still on the smaller cards .. it's an eggs & baskets thing.
Apr 09, 2008 at 08:43 PM
alixmiles
p.1 #17 · Anyone using 16GB CFs?
I probably have more faith in mine than I should.
I had just come home from shooting a senior session and took my card out. I set it down on the island in our kitchen. I made the mistake of setting it on the placemat.
My wife had a pan full of water in one side of the sink.
She picked up the placemat to shake it off and the card went into the pan of water.
I didnt see it happen and didnt even miss the card for about 5 minutes. I went to pick it up and go dl the pics and couldnt find it. We looked all over for it. Finally found it in the bottom of the pan. So at this point it was probably under water for at least 8-10 minutes.
I almost killed her. So my thoughts were this. I could wait and see if it would dry out...but I was also worried about water eventually seeping into the card. Or I could try to grab the images right away and hope i didnt fry the card or my comp.
I took a hair dryer to it for about 2 minutes and loaded into my card reader.
Guess what, not a lick of trouble or corrupted image.
In fact I still use this card today. i have recently bought some 4gb ultra2 cards from costco...couldnt pass them up at 28 dollars.
All my cards are sandisk ultra 2.
Barry
Apr 09, 2008 at 09:42 PM
fchang
p.1 #18 · Anyone using 16GB CFs?
I know some of Canon's won't take more than 8gig CF & I think 5D is one, my 30D is another.
Apr 09, 2008 at 10:10 PM
clausjepsen
p.1 #19 · Anyone using 16GB CFs?
I have a 1 GB card that I gave a ride in the washingmashine. During this it got a dent in the pin end. Thought it was dead, so in my workbench I pressed the dent back in position, so it was possible to put the card back in the camera. And it worked. I still use it.
Once I got corrupted images, where only 10 to 50 percent of each picture was ok. I think it was my cardreader that made the problem, so I changed it and have had no problems since.
Yesterday my Epson 2000 said, that the 2 GB Lexar card was corrupted, but I could see all the pictures on my 5D.The rest of the day (1000 pics) the doubt was there.
So I am looking foreward to get a 1Ds3(or2) so that I can store my pics on two cards and then I will have no problems going for a 8 GB card, but until then I will stick with my 2 GB card.
Apr 09, 2008 at 11:52 PM
kdphotography
p.1 #20 · Anyone using 16GB CFs?
The latest firmware update for the 5D now allows the use of higher capacity CF cards.
The higher the demand of memory from the camera, the more you need a higher capacity card---this is especially true when shooting with a medium format digital. I won't buy anything less than 8GB now, and 16GB just doesn't seem to be so huge anymore......
Apr 10, 2008 at 12:20 AM
       2       3       end
       2       3       end
