I've never had that one.. What are your settings for import? Also, try a command click on the folder on the left hand side and Synchronize. See if that helps!
1 - When you import pic in LR and work on it, at the same time if you accidently work on the same picture outside of LR i mean like in Photoshop chances are this thing will happen.
2nd - You have to import the original picture from the card again
Jonathan Consiglio
Same here. Try the "sync folder" and see if that fixes things.
