Archive 2008 · Help...C/Y adapter fro Canon 5D
Paul Yi
p.1 #1 · Help...C/Y adapter fro Canon 5D
I'll be receiving this thursday 2 contax lenses...(35-70/3.4 and 100/2 Planar T*)
Where can I get the most reliable adapter for my 5D?
Will they be with AF confirmation?
Will the adapters be identical for the both lens?
I've read from past post that I need to shave the fin of the lens...Is there any other way to go around this method? (I'm scared to physically alter either the lens or the camera)
Sorry for the newbie questions....I thought I've done enough reasearch before ordering these lens, but I'm kinda cloudy in regards to the adapters.
Apr 07, 2008 at 06:38 PM
johnahill
p.1 #2 · Help...C/Y adapter fro Canon 5D
I use Fotodiox pro adapter for my 35-70/5D, works ok except the mirror gets caught on verticle shots, mirror drops back when I turn the cam around back to horizontal though
Apr 07, 2008 at 06:59 PM
Paul Yi
p.1 #3 · Help...C/Y adapter fro Canon 5D
Thank you, Johnahill.
I need adapters without such problems....
Apr 07, 2008 at 07:12 PM
jonboring
p.1 #4 · Help...C/Y adapter fro Canon 5D
See http://www.16-9.net/lens_tests/adapters_5d.html
I use the happypagehk confirm adapters and have had good luck with them. He doesn't have any posted for sale right now on eBay but email him and he'll probably be able to help you. See http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZhappypagehkQQssPageNameZSTRKQ3aMEFSXQ3aSRCH
It is preferable to modify the mirror rather than the lens. The mirror can be replaced but not the rear fin. However, don't try it yourself without lots of study first. You might get lucky and not have to do it - seems to be body specific. You can also use a thicker adapter to avoid mirror issues but then you give up true infinity focus.
Apr 07, 2008 at 07:16 PM
Paul Yi
p.1 #5 · Help...C/Y adapter fro Canon 5D
If I bring my camera to a local camera repair shop, will they be able to modify the mirror? If so, does this mean that I do not need an adapter?
Also, if I modify the mirror, will there be any problem with current canon lenses?
Again, sorry for a lot of questions.
Apr 07, 2008 at 07:41 PM
jonboring
p.1 #6 · Help...C/Y adapter fro Canon 5D
No local repair shop probably will not do it and you still need an adapter. The adapter allows the Contax lenses to fit the Canon mount. However, sometimes the edge of the 5D mirror hits the Contax lenses when the shutter is released. This does not cause any damage and if you release the lens from the Canon mount, the mirror returns to the normal position. But you don't want to do this each time you press the shutter. By shaving 2mm off the edge of the mirror, this solves the problem. However, this does not happen all the time. You may get lucky and your 5D may work fine.
Apr 07, 2008 at 08:39 PM
p.1 #7 · Help...C/Y adapter fro Canon 5D
My 35-70/3.4 doesn't hit the 5D mirror, but my Distagon 35/2.8 did. I recommend you trim the base of the lens, not the mirror. In most cases, it's the shield tab that protects the aperture control lever that hangs up on the mirror. One quick snip with a pair of wire cutters will solve that problem. OTOH, some lenses like the Distagon 15/3.5, 18/4 and Leica-R 15/3.5 may require a mirror adjustment. Consider the difference in value between the lens and camera before you decide which one to modify.
Apr 07, 2008 at 09:53 PM
jonboring
p.1 #8 · Help...C/Y adapter fro Canon 5D
yes but if you trim the mirror, you can replace it. if you trim the lens, it is permanent
Apr 08, 2008 at 12:39 AM
Paul Yi
p.1 #9 · Help...C/Y adapter fro Canon 5D
I can't find e-mail address for happypagehk.
Does anyone have it?
Apr 08, 2008 at 02:17 PM
Paul Yi
p.1 #10 · Help...C/Y adapter fro Canon 5D
Is Haoda adapter reliable?
Do I need to do shave either a lens or camera mirror if I use their adapter?
Please help me to choose an adapter.
My lenses are coming tommorow.....
Apr 09, 2008 at 04:53 PM
veroman
p.1 #11 · Help...C/Y adapter fro Canon 5D
Go to http://haodascreen.com/cyeos.aspx
Haoda is having a sale right now on his auto-focus confirm adapters. More than half off I think. Highly recommended. I've bought several from him. They are beautifully made. I've had no trouble with my lenses hitting the mirror of my 5D.
I doubt you can get them right away, though. Takes a couple of weeks. You'll have to email him and see if he can expedite things.
Good luck,
Steve
Apr 10, 2008 at 02:49 AM
B Landau
p.1 #12 · Help...C/Y adapter fro Canon 5D
I had problems with my 5D mirror hanging up on both the 35-70 and 28 CZ lenses when using happypagehk adapters. Had absolutely no problem in returning the happypagehk adapters. Tried a Bob Shell adapter and had the same problem (I would not recommend doing business with this guy). Eventually got the standard Fotodiox adapter to work with both lenses.
Apr 13, 2008 at 04:55 AM
