BobCollette Offline Image Upload: Off
p.1 #2 · Printing Photos & Detail in Whites | |
I downloaded your image, and I see that it's in Adobe RGB color space. Be aware that many printing services want/expect the image to be in sRGB color space. Treating an Adobe RGB image as though it was sRGB makes the image appear to have less contrast and color saturation. You can view the difference by opening the image in Photoshop selecting "Use Embedded Profile", and then pretend to assign the sRGB profile to the image. If you have Preview turned on, as you toggle the assigned profile between Adobe RGB and sRGB (before pressing OK), you'll see the image change, showing the effect of a mismatched color space profile.
As to your original question, I'm guessing that the printer isn't quite properly calibrated in the highlights. It's very tricky to get a photographic printer properly calibrated in the highlights. If the highlight contrast is too low, you lose highlight detail, if it's too high, it accentuates any noise (primarily shows in blue sky/clouds looking blotchy).
