Allen Hirsch Offline Image Upload: Off
Equinox wrote:
thx everyone! This helps alot. The only concern i have is the image quality loss in the 70-300. If i am going to be shooting wildlife, i want as much detail captured as possible, and the L will give more detail im sure. I guess there is no perfect lens... Anyone know if IS helps in wildlife? I know it don't help in sports, but what about wildlife. Do you need a fast shutter speed like sports, to the point where IS becomes obsolete?
Again, it depends on what you're shooting, and the focal length you're using. 400mm and under, you can be handheld most, if not all, the time. Then IS will definitely be helpful. With most bigger wildlife, you won't be needing such a fast shutter speed, so, again IS will be helpful (if nothing other than to give you extra stops for a shallower DOF).
500mm and longer, you'll be using a tripod or monopod all the time, most likely. Then, IS is mostly helpful just for DOF considerations.
Frankly, if you're as budget-constrained as you indicated in your first post, you HAVE to expect to give up something, b/c you're certainly not getting long reach, IS, and L-level IQ for cheap. In fact, you'll probably have to settle for just one of the 3 attributes, at best, at the price point you've mentioned.
