       2       3       end
Archive 2008 · 5D - What Focus Screen
johnahill
p.1 #1 · 5D - What Focus Screen
I've recently got my first 5D, and now looking at what extras I need.
I'm using Contax/Oly and soon Leica lenses together with some EF lenses.
What screen should I get to aid manual focus?
My lenses range from f1.7 to f4.0 max aperture.
Unless you guys have other recommendations, I'll start with the EE-S and go from there.
Mar 18, 2008 at 11:37 AM
s23chang
p.1 #2 · 5D - What Focus Screen
please check with "Best way for manual focusing? " thread
Mar 18, 2008 at 11:46 AM
jonboring
p.1 #3 · 5D - What Focus Screen
I have the Brightscreen split/microprism and love it. However, only evaluative metering work without exposure compensation. Something about the screen screws up the metering, at least some of the time with the other metering modes. With the histogram, it doesn't cramp my style too much and I love the split. With the combo of the split and confirm adapters, I find focusing the manual lenses fairly easy most of the time.
Mar 18, 2008 at 02:32 PM
StevenPA
p.1 #4 · 5D - What Focus Screen
https://www.fredmiranda.com/forum/topic/617202
This thread has a lot of useful info about different screens for the 5D.
Mar 19, 2008 at 07:11 PM
Kit Laughlin
p.1 #5 · 5D - What Focus Screen
I had a Brightscreen in my 5D too, and have only good things to say about it. I had the large microprism-only version, though, and I found this perfect with MF Zeiss and Leica glass. I was shooting a lot of portraits then, and with the Apo 90/2 and shooting close up, I could see focus being pulled along a bottom lid. cheers, kl
Mar 19, 2008 at 08:20 PM
theophilus
p.1 #6 · 5D - What Focus Screen
I use the Canon E-es screen. Works great but gets really dark after f/2.8. There is a company that can add some coatings to reduce light fall-off, I will probably do this soon.
Mar 20, 2008 at 10:38 PM
R10
p.1 #7 · 5D - What Focus Screen
I also use the Ee-S screen. For me it's perfect, even with my f4-Leica-Varios. For me, it doesn't get too dark even at f4 (but I 'grew up' with MF and much darker finders). Split screens and/or microprisms may facilitate manual fosussing but I'm rather distracted (in terms of image composition) by these central structures. A plain matte screen makes image composition much faster and easier for me, also because I rarely focus on the center. With the Ee-S screen, the plane of focus is quite distinctly visible and cogitech put it nicely in the thread linked above by StevenPA:
A plain matte screen "is like having infinite AF points, with eye control".
Cheers
Mar 26, 2008 at 01:47 PM
R10
p.1 #8 · 5D - What Focus Screen
Brief follow-up
I use the Ee-D screen (with grid) now. Contrary to the descriptions of this screen all over the net, it is not just an Ee-A with grid, but almost as contrasty as the Ee-S, ie well suited for manual focusing. Since the grid of the Ee-D helps me a lot while being still contrasty enough for manual focusing, it's my favorite over the Ee-S.
((If one is not sure about the difference in contrast (or brightness, rsp.) between the three screens named above, there is an easy test: Just take three pictures (identical scene and light) in A-mode with the same screen (whichever you want/have), one picture for each of the three screen custom settings (#00, were the 5D corrects for screen brightness), and compare the resulting three histograms! The Ee-D result is much closer to the result with Ee-S setting than to that of the standard Ee-A setting.))
Edited on Nov 14, 2008 at 12:47 PM · View previous versions
Nov 12, 2008 at 01:54 PM
Silentlight
p.1 #9 · 5D - What Focus Screen
I went from Ee-D to Ee-S to Ec-CIV (shaved and shimmed), and so far like the Ec-CIV the most. Although I wish it had the grids of Ee-D.
Nov 12, 2008 at 07:40 PM
shirozina
p.1 #10 · 5D - What Focus Screen
http://www.slrdaren.com/index.php?main_page=index&cPath=65_71
look at the 3 at the bottom for the 5D but check the Canon listing for what is on the screeen as I thought I was gettting a split screen with microprism but it turned out only to be a split screen. Because of the center focus mark the split screen is not that useful. The matte part is much better than the Ee-s though and worth it for this alone.
Nov 13, 2008 at 04:34 AM
brainiac
[X]
p.1 #11 · 5D - What Focus Screen
Ee-S
Nov 13, 2008 at 11:50 AM
prashant
p.1 #12 · 5D - What Focus Screen
is Ee-S really a great improvement over standard screen while using manual lenses? I have all my lenses with f2.8 or lower, may be interesting.
Nov 14, 2008 at 09:02 AM
johnahill
p.1 #13 · 5D - What Focus Screen
Yes it is. I use it on mainly 2.8 lenses and the 3.5 vario sonnar and it works like a charm.
Nov 14, 2008 at 09:18 AM
cogitech
p.1 #14 · 5D - What Focus Screen
It is dramatically better. Don't even hesitate to try one.
Nov 14, 2008 at 09:47 AM
Paul Yi
p.1 #15 · 5D - What Focus Screen
I've used Bill Maxell's "Hi-Lux" Ee-S screen, and it is fantastic.
I don't have 5D now, but I'm saving the screen just in case I get the 5D again.
It's that good.
Nov 14, 2008 at 09:50 AM
prashant
p.1 #16 · 5D - What Focus Screen
umm, ok. And what happens when I also have EF lenses? Should work fine, right? I'm about to order one.
Nov 14, 2008 at 10:59 AM
cogitech
p.1 #17 · 5D - What Focus Screen
Works identically. In fact, your EF lenses will also be easier to manual focus, of course, and AF is not affected at all by the screen.
Nov 14, 2008 at 11:03 AM
prashant
p.1 #18 · 5D - What Focus Screen
so Ee-S it is. Thanks Cogitech. Thanks to all others.
Nov 14, 2008 at 11:08 AM
dcains
p.1 #19 · 5D - What Focus Screen
+1 - just installed one a few days ago in my 5D.
Nov 14, 2008 at 11:30 AM
shirozina
p.1 #20 · 5D - What Focus Screen
Ee-S is only a little better than the standard screen - you realy need to try a modded series 1 screen to see manual focus accuracy in action.
Nov 14, 2008 at 12:14 PM
       2       3       end
       2       3       end
