Archive 2008 · Use of flat-screen TV to edit photos
mkweaver
p.1 #1 · Use of flat-screen TV to edit photos
Is it possible to use a flat-screen TV as a monitor to show people their photos? Can it be color calibrated like a monitor?
Or would I be better off to purchase a large monitor, or a projector system?
Any help or experiences would be appreciated.
Mar 14, 2008 at 04:09 PM
scott shoemake
p.1 #2 · Use of flat-screen TV to edit photos
Apple cinema displays are hard to beat for large screens...I've heard good things about Sharp Acquos (sp?). They mainly use it for displaying slideshows, etc...
Mar 14, 2008 at 04:37 PM
mkweaver
p.1 #3 · Use of flat-screen TV to edit photos
Thanks!
Mar 14, 2008 at 04:44 PM
AJ Nadershahi
p.1 #4 · Use of flat-screen TV to edit photos
Spyder Pro can calibrate large monitors and projectors.
Just attach it to a tripod and point it at the screen, connect your computer to the monitor or projector, then follow the step by step instructions.
The biggest limitation is the level of adjustments available on your monitor or projector. With the right equipment it makes a noticeable difference.
Edited on Mar 15, 2008 at 05:55 AM
Mar 15, 2008 at 05:54 AM
RDKirk
p.1 #5 · Use of flat-screen TV to edit photos
It largely depends on what you want to show and under what conditions.
I use a projector because I want to show large and I frequently show at my clients' homes (projecting into the space the portrait will inhabit). Projectors that will project a 30x40 image are far cheaper, more compact, and lighter than a monitor that would show a 30x40 image.
Mar 15, 2008 at 08:17 AM
kesava
p.1 #6 · Use of flat-screen TV to edit photos
large plasmas/lcds do not have the resolution to do high-end editing.
Mar 15, 2008 at 10:23 AM
CTYankee
p.1 #7 · Use of flat-screen TV to edit photos
previewing or showing photos to people at a distance, yes they are useful, but a projector is more versatile and a lot smaller!
Editing or anything other than looking...forget it.
Mar 15, 2008 at 12:47 PM
mdude85
p.1 #8 · Use of flat-screen TV to edit photos
Optimal images on projectors require the absence of almost all light. If you cannot deliver that, then the images will look washed out.
Mar 15, 2008 at 04:47 PM
mdude85
p.1 #9 · Use of flat-screen TV to edit photos
1080p does
Mar 15, 2008 at 05:15 PM
CTYankee
p.1 #10 · Use of flat-screen TV to edit photos
mdude85 wrote:
1080p does
Sorry, thats just not true. yes they have decent resolution, but the dot pitch is so bit that detail is miserable. Plasmas and LCD TVs are good for viewing images, nothing more. Not to mention color accuracy is marginal. Using a flat panel for editing would be a nightmare.
Mar 15, 2008 at 10:06 PM
CTYankee
p.1 #11 · Use of flat-screen TV to edit photos
They actually look very similar to what the final print looks like. if you get 300:1 contrast on the projection then you are right in range with paper.
Mar 15, 2008 at 10:09 PM
HerbChong
p.1 #12 · Use of flat-screen TV to edit photos
300:1 is over 8 stops. that is way beyond the best paper, which is a little over 5 stops (i.e. 32:1) under optimal conditions.
Herb...
Mar 15, 2008 at 10:25 PM
CTYankee
p.1 #13 · Use of flat-screen TV to edit photos
Herb...
I think I had the standard 300ppi figure on my brain....but I have seen photo paper (BW anyway) measured at 100:1. However point remains...prints are washed out and a projector can actually out do a print even in a lit room.
Mar 15, 2008 at 10:44 PM
mdude85
p.1 #14 · Use of flat-screen TV to edit photos
I wouldn't advocate using a TV to edit images, but to suggest that the reason not to use them is that they have low resolution, is actually incorrect. 1920px is enough resolution. That's all my post speaks to.
Mar 16, 2008 at 02:19 AM
HerbChong
p.1 #15 · Use of flat-screen TV to edit photos
i'd like to see one of those prints. my Harman Gloss on my 3800 tops out at about 6 stops.
Herb....
Mar 16, 2008 at 08:18 AM
RDKirk
p.1 #16 · Use of flat-screen TV to edit photos
Moreover, those considerations matter more to photographers than to clients. Clients are impressed, first of all, by the size of the image. Relatively few people can envision the impressiveness of size without actually seeing it (at least envision it well enough to easily pay more for it).
Show them on their own wall an 8x10 and then show them a 30x40, and you'll at least get a 20x30 sale. Contrast is far less of a factor.
Mar 16, 2008 at 08:59 AM
MRoach
p.1 #17 · Use of flat-screen TV to edit photos
I really agree with RDKirk, the gallery that sells much of my work does so to office makeovers in the legal and medical industries, and the gallery brings a projector and CD of images to the customer and projects on the office wall (or a portable screen If the wall color is too dark) and they project at different sizes and I custom print to order. Much of this is done before the office is completed and the walls are still only primer painted or in the white. The prints arrive about the time the offices receive their final accessorizing. Bigger is really better in terms of making the sale.
Michael R
Mar 16, 2008 at 05:27 PM
Baldur
p.1 #18 · Use of flat-screen TV to edit photos
well, I hook up my MacBook to the 50" plasma in the living room quite often to watch films and for using Frontrow to listen to music and watch podcasts and whatnot, the quality is quite amazing actually. I work on a 30" cinema display and if you are talking about previewing your images to non professional clients then go for a large or extra large HD plasma screen, why plasma. Well I looked at a bunch of options and the plasma simply blew LCD out of the water when it came to the "feel" of the image. For any real work on the images it's useless but if you want to sell your wedding stuff or do in office presentations then go for it. This is one example where more is more. If you have money to burn they have 103 inch models for around 120.000 us and the price of the 150 inch was somewhat more, well, hmm, closer to the Bugatti Veyron but then again.
A decent plasma in the 42 - 50 inch range is about the same price as a decent projector that can show your stuff in 150 inches but then you really are throwing image quality out of the window, you have to darken the room, no real whites, no real blacks, don't bother.
A non professional client is not going to care if the exact gamut of the screen or the native resolution is optimal, they are not going to know if you run Adobe 1998 or Pro Photo, but they will buy more images and bigger prints if they see their images in a large format from the get go, it's easy to make impressive slideshow presentations in Lightroom and other programs and it works, I seem to recall a system for sale in the late to mid nineties where you bought a really expensive kit with a back projection system for wedding/portrait photographers which increased many photographers sales, now you can do it off your laptop and a 1500 dollar flat screen tv.
just my two cents
Mar 17, 2008 at 02:54 AM
mkweaver
p.1 #19 · Use of flat-screen TV to edit photos
Thanks for all the very helpful comments. I really got exactly what I needed. Pros and cons!
This is the best! Thanks again!
Mar 17, 2008 at 09:00 AM
