Archive 2008 · Lastolite vinyl background
spijker
p.1 #1 · Lastolite vinyl background
I came across the Lastolite Superwhite Vinyl Background on the web;
http://www.lastolite.com/superwhite-vinyl-backgrounds.php
Looks like it's a good replacement for the paper backgrounds. Give it a wipe after the shoot and you'll always have a clean background. Does anyone have any experience with this, an opinion? I'm considering buying this for the photo club's studio instead of the white background paper.
Menno
Edited on Mar 13, 2008 at 03:00 PM
NickyD
p.1 #2 · Lastolite vinyl background
I always found that vinyl reflected too much light...but I like lastolite. So, this might be worth looking in to.
Mar 13, 2008 at 03:47 PM
Nathan67
p.1 #3 · Lastolite vinyl background
I have a roll in my studio, use it all the time, it has a matt finish which does not reflect too much light back.
Be warned it is very heavy, so wall mounted brackets would be a good idea. (15kg)
Also if you are using the manfrotto roll system then you will need to swap the plastic chain for the metal chain.. I broke several plastic chains...
Hope this helps.
Nathan
Mar 16, 2008 at 03:43 AM
spijker
p.1 #4 · Lastolite vinyl background
Thanks Nathan, that is helpfull. How is strong is the vinyl? Can it withstand high heeled shoes of the models? Is as easy to clean as Lastolite advertises?
Menno
Mar 17, 2008 at 10:18 AM
Carmen Miranda
p.1 #5 · Lastolite vinyl background
Menno,
I've got the apron for the Hi-Lite, which is the same stuff. It is strong and very easy to clean. Shoes no problem, high heels not recommended.
Good luck.
Mar 17, 2008 at 10:39 AM
Nathan67
p.1 #6 · Lastolite vinyl background
Menno
As Carmen said, very easy to clean, no problems so far, even with heels...be careful with spike stilettos though, especially if you use it over a carpet like floor covering
Nathan
Mar 17, 2008 at 06:23 PM
el_hoppy
p.1 #7 · Lastolite vinyl background
I just logged on here to post the exact same questions. Lucky I browsed first
How well does the background sit? I have been finding that as I get near the end of my paper roll, the paper gets a bit wavey with shadows in sections when I am not shooting high-key.
Mar 18, 2008 at 09:03 AM
Carmen Miranda
p.1 #8 · Lastolite vinyl background
el,
Should not be a problem for two reasons:
1. roll comes on an aluminum core
2. white vinyl is meant strictly for high key
Good luck
PS. Nice site, el.
Edited on Mar 18, 2008 at 03:19 PM
Mar 18, 2008 at 09:55 AM
alixmiles
p.1 #9 · Lastolite vinyl background
I have the one from denny manufacturing. they are having a sale right now. I think it is 50 percent off. i like mine but it is big and bulky and heavy. i bought it to do a christmas shoot with santa and a tree and kids. we do a charity breakfast with santa each year. if i had paper or muslin it would have been ruined. all the snow and wetness here in the midwest. I thought about buying another one but not 12 feet wide. i would like one about 6 feet wide. i used it once in my living room for a family shot before i got my temp studio going. I would have liked for mine to come with a different way to mount it. it has a 2x3 inch wood frame on one end and a round rod that has been split and bolted back together on the other end. people trip over it.
just my thoughts
Barry
Mar 19, 2008 at 07:07 PM
Umbro
p.1 #10 · Lastolite vinyl background
Thought this might be of interest,
I use a white vinyl BG, it's actually vinyl thats used for curtain sided lorries/ container covers etc.
The thing is it's exactly the same as what lastolite uses but at a fraction of the cost.
Try your local tarpaulin manufacturers. The product name here in the UK is "V5"
Hope this helps
Mar 20, 2008 at 09:44 AM
Umbro
p.1 #11 · Lastolite vinyl background
A quick shot with the BG
Mar 20, 2008 at 09:45 AM
alixmiles
p.1 #12 · Lastolite vinyl background
The one I have does not have the sheen on it I see in Umbro's
Mar 21, 2008 at 11:23 AM
Umbro
p.1 #13 · Lastolite vinyl background
The other side of the vinyl has a matt sheen to it, but is a little textured.
The idea of the gloss side is that when used for lorry curtains/tilts is that road dirt will not stick to it as easily as the textured/inside side.
I second the advice mentioned by Nathan.
If you're gonna be using the vinyl on a Manfrotto system use the metal chains.
If using the plastic chains, one trick you can use is to gather the vinyl back up under the pulley before trying to re roll it.
The material is quite heavy and the plastic chains don't have the guts to be able to pull the materials along the floor and then onto the roll.
Mar 22, 2008 at 04:35 AM
TTLKurtis
p.1 #14 · Lastolite vinyl background
Did anyone ever find a 6x16' white vinyl backdrop?
http://www.prostudiousa.com/White-Vinyl-Background-P323C0.aspx
These folks said they will cut down an 8x16' to 6' wide if I want, but the price is a little higher than I thought it would be at $279.
Savage's 8x20' is only like $150 at BHPhoto... But I need it in 6' wide.
Mar 13, 2009 at 11:32 AM
Jackal2854
p.1 #15 · Lastolite vinyl background
How about Savage Vynil BG...Has anyone used them? I am looking at them and wondered if they are comparable in quality to the Lastolite.
http://www.bhphotovideo.com/c/product/562131-REG/Savage_V01_1020_Infinity_Vinyl_Background_.html#accessories
Thanks
Mar 13, 2009 at 07:44 PM
RobertLynn
p.1 #16 · Lastolite vinyl background
TTL, depending on what it's made out of, and if you are feeling brave, buy the 8X20, and cut it yourself. I imagine with a straight edge, and a good sharp titanium alloy utility blade, you'll be just fine. After all the exact edge I wouldn't think would have to be "perfect".
Mar 13, 2009 at 08:03 PM
photojack
p.1 #17 · Lastolite vinyl background
Another type of vinyl that I have been using is marine vinyl. Its used for upholstering boat seats and furniture. Sits nicely. Not glossy. Has a little bit of stretch and texture but not noticeable at all in any shots.
Mar 13, 2009 at 09:08 PM
tutumon
p.1 #18 · Lastolite vinyl background
Mind sharing where you bought this?
Mar 16, 2009 at 08:29 PM
mkeverything
p.1 #19 · Lastolite vinyl background
Also interested in the Savage Vinyl - Anyone use it - recommend it?
Thanks
Mar 16, 2009 at 10:07 PM
Wm. Velasquez
p.1 #20 · Lastolite vinyl background
tag
