       2       3              12       13       end
Archive 2008 · 7D imminent?
Venus
p.1 #1 · 7D imminent?
This?
http://www.upcdatabase.com/item/0013803086706?session-id=09efcaec061a52eb8f977cab223ea7f4
Also just back from Hong Kong. Seems that a number of knowledgeable
dealers there also smell that the 5D replacement is on the way. Folks there refer to 5D as "end of line model".
Mar 10, 2008 at 12:06 AM
Stunnaz
p.1 #2 · 7D imminent?
4D imminent?
http://www.upcdatabase.com/item/0013803023787
2D imminent?
http://www.upcdatabase.com/item/0013803029024
Mar 10, 2008 at 12:18 AM
Venus
p.1 #3 · 7D imminent?
Ok, ignore that site. Maybe not 7D. But 5D replacement's name still unknown.
Mar 10, 2008 at 12:27 AM
Stunnaz
p.1 #4 · 7D imminent?
5D will be replaced soon... that's for sure. At the very least it'll be a 40D with a full-frame sensor. Consider anything beyond that a bonus and you will not be disappointed.
Mar 10, 2008 at 12:29 AM
Venus
p.1 #5 · 7D imminent?
looks like it's only a 13 mp full frame sensor. bigger buffer and 14-bit amongst other things.
Mar 10, 2008 at 12:41 AM
Gochugogi
p.1 #6 · 7D imminent?
The 5D has a 12.8MP full frame CMOS. Basically it's already 13MP. Surely Canon will bump it up further than .2MP!
Mar 10, 2008 at 01:09 AM
PasiM
p.1 #7 · 7D imminent?
No need for a crystal ball to tell 5D is going to be replaced. Sometime in a year.
Mar 10, 2008 at 01:11 AM
Antony
p.1 #8 · 7D imminent?
5D will be split into 2 models. Lower end model will retail at sub $2000 and be basically a full frame 40D with a 13MP sensor, built in flash and slow frame rate (3 fps). ISO to 6400. Smaller VF image than 5D due to reduced size of prism. Camera will be pitched at the high-end amateur seeking FF over speed.
Higher end model will retail for $3199 on launch and will feature watersealing on a par with 1 series, higher frame rate (4.5 fps), and a 16MP chip. ISO to 6400. Better focus inc. focus to f/8 at centre point and x type points at the extremities of the focus ellipse (however still 9 point). Camera will be marketed as a pro model, appealling to wedding photogs and those seeking smaller form factor (similar approach to the launch of the 5D). AF micro adjustment available.
Both camera will launch at photokina. Expect a big fuss.
Mar 10, 2008 at 02:08 AM
Josh Bustos
p.1 #9 · 7D imminent?
and you know this how?
Mar 10, 2008 at 02:25 AM
Tentacle
p.1 #10 · 7D imminent?
Seems a good guess to me. Though I'm not so sure if they will go the build-in flash route. One of the big benefits of full frame is a nice and bright viewfinder. Why chip that benefit away when you want to entice photographers to go full frame?
And that would totally butcher the flagship 1Ds Mk III sales. Why would Canon do such a stupid thing?
Mar 10, 2008 at 02:45 AM
mjkoolio
p.1 #11 · 7D imminent?
So maybe the 3D?
Mar 10, 2008 at 02:53 AM
Venus
p.1 #12 · 7D imminent?
listen to anthony...
Mar 10, 2008 at 03:08 AM
Tentacle
p.1 #13 · 7D imminent?
Erhh, why? Except for good guesswork on the lower spec 5D Mk II, there is little that seems realistic to me. No sources, no proof. I'm not saying he's wrong, no guarantees for that either, but a claim like this could use some substantiation.
Mar 10, 2008 at 03:18 AM
Tim Ashton
p.1 #14 · 7D imminent?
So Antony.
word is Nikon took over marketing in Australia because of the leaks that emanted from Maxwells, Sounds like the "mole" has gone across to Canon .
Cant complain though; we all love a good leaker
If you are right there is going to be a lot of upgrade envy.
Cheers
Tim
Edited on Mar 10, 2008 at 03:21 AM
Mar 10, 2008 at 03:19 AM
Lawrence Lee
p.1 #15 · 7D imminent?
I agree with you that his guess seems like a good one. I don't think the "higher end model" will destroy the 1DS MK III because the 1DS camera have a higher resolution sensor. I can't think of any other features the 1DS have at the moment that would justify the $7000+ for it, but that is one thing that I can think of at the moment.
Tentacle
p.1 #16 · 7D imminent?
The 5D definitely took a bite out of 1Ds Mk II sales. That was 12.8 vs. 16.7 Mpixel. With the proposed 16 Mpixel vs. 21 Mpixel, you're looking at a similar gap of about 30%.
"Butcher" may have been exaggeration, but still a high-spec 5D II like suggested will cause a noticeable dent in 1Ds Mk III sales. Especially if both have full weathersealing and very close fps rates.
Mar 10, 2008 at 03:44 AM
Pixel Perfect
p.1 #17 · 7D imminent?
One word - PHOTOKINA
5D will be replaced in September 100% guaranteed. Looks like they've stolen my specs for the upmarket version.
Mar 10, 2008 at 03:46 AM
Tentacle
p.1 #18 · 7D imminent?
I agree, the likelihood of seeing a successor to the 5D at Photokina is so high it can be called 'certain'. But specs? I'm not sure.
  1. ***D series
  2. **D series
  3. 3D?
  4. 5D [exit?]
  5. 7D?
  6. 1D series
  7. 1Ds series
That seems awfully crowded for a product portfolio. And if you want to keep it realistic, you have to compare this to the Nikon range, which is staggered/shifted compared to the price brackets of Canon.
  1. D40/50/60
  2. 450D
  3. D80/D90?
  4. 40D
  5. D300
  6. 5D
  7. 1D Mk III
  8. D3
  9. 1Ds Mk III / D3x?
So where would you place a 3D and 7D? The current 5D spot, above the price range of the D300, looks like sweet spot to me.
Edited on Mar 10, 2008 at 04:07 AM
Mar 10, 2008 at 04:01 AM
Tentacle
p.1 #19 · 7D imminent?
Oh, and in case it's not clear from the above, my guess is we'll see a 5D Mk II. Though I may be completely wrong off course.
I would just like to be able to get a 12 Mpixel ISO 6400 full frame camera at affordable price. If that means I can't have 6 fps, weathersealing, 45 pt AF, then so be it. 40D AF unit and 4 fps would be fine with me.
Mar 10, 2008 at 04:16 AM
Yakim Peled
p.1 #20 · 7D imminent?
Antony, can you state your source?
Happy shooting,
Yakim.
Mar 10, 2008 at 04:29 AM
       2       3              12       13       end
       2       3              12       13       end
