Archive 2008 · Contax 645 lens on eos
DanPBrown
p.1 #1 · Contax 645 lens on eos
Howdy all. Could someone tell me if it is possible to mount a Contax 645 lens to a Canon body? In particular I'm interested in this lens, Apo-Makro-Planar T* 120mm f/4.0.
If it is possible do any of you have experience with this lens?
I like the idea of using a medium format 1:1 macro lens with the 1dsmk3 and a shift adapter.
Thanks,
Mar 06, 2008 at 08:39 PM
Dergiman
p.1 #2 · Contax 645 lens on eos
conurus.com is working on that adapter but it isn´t for sale yet. you should expect it to be quite pricey.
Mar 07, 2008 at 01:48 AM
DanPBrown
p.1 #3 · Contax 645 lens on eos
Will the 120 Contax resolve enough for the 1dsmk3? It seems to have very good mtf.
Mar 07, 2008 at 07:55 AM
Conner999
p.1 #4 · Contax 645 lens on eos
Check out www.getdpi.com Medium Format section. Son shows pics from Hassy 110 on a 5D - look bloody fine to me.
Also check fotodiox - they sell a number of MF-to-EOS adapters.
Edited on Mar 07, 2008 at 08:07 AM
DanPBrown
p.1 #5 · Contax 645 lens on eos
Thanks for the replies. Will the 120 makro stop down manually or does it need a special adapter? I'm not interested in autofocus functions.
Thanks,
www.danbrownphotography.com
Mar 07, 2008 at 08:13 AM
Dergiman
p.1 #6 · Contax 645 lens on eos
the aperture on the c645 lenses is electronically controlled, so you need electronics to close the aperture.
Mar 07, 2008 at 08:30 AM
DanPBrown
p.1 #7 · Contax 645 lens on eos
Bummer, I was hoping it wasn't an electronic shutter. Are there any 120mmish medium format 1:1 macro lenses that are manual aperture and have similar image quality to the 120 contax 645?
Thanks,
Mar 07, 2008 at 07:03 PM
wyan
p.1 #8 · Contax 645 lens on eos
Thanks,
I think there are quite a few of great 135 macro lenses. Unless you have already own a 120 system, there is no point going through the hassles. Just my 2 cents.
Mar 07, 2008 at 08:04 PM
DanPBrown
p.1 #9 · Contax 645 lens on eos
My goal was to be able to mount a medium format macro lens with a zoerk adapter so that I could stitch macro shots. My main concern is the resolving power of some medium format glass when coupled to a 1dsmk3.
Mar 07, 2008 at 08:59 PM
DanPBrown
p.1 #10 · Contax 645 lens on eos
Will it be a shift adapter? That would be a big plus when using medium format, otherwise I don't see the advantage of using MF.
Edited on Mar 09, 2008 at 09:06 AM
Mar 09, 2008 at 09:05 AM
Dergiman
p.1 #11 · Contax 645 lens on eos
yes it should be a shift adapter, but no tilt.
Mar 09, 2008 at 11:46 AM
