Archive 2008 · Which pen to use for signature?
Sukey
p.1 #1 · Which pen to use for signature?
I'm glad someone brought up the question re: signing prints. But I'm still wondering, does someone has experience as to what is the best type of pen to use to use?
I'll be needing it to sign directly on the print which is printed on a resin-coated, glossy paper.
Black would probably be too obtrusive for me, but a pen that comes in other colors would be great (such as silver).
Mar 06, 2008 at 06:28 PM
colinm
p.1 #2 · Which pen to use for signature?
I'm partial to the Sakura Pigma Micron. They don't come in silver, but they are archival and come in a variety of colors.
Mar 06, 2008 at 06:33 PM
Sukey
p.1 #3 · Which pen to use for signature?
And you have no problem with them 'skipping' on glossy prints? I'm really worried about that.
Mar 06, 2008 at 06:35 PM
rrwingnut
p.1 #4 · Which pen to use for signature?
David Ziser has a video tutorial on doing this in photoshop here:
http://digitalprotalk.blogspot.com/search?q=john+henry
Mar 06, 2008 at 07:13 PM
Sukey
p.1 #5 · Which pen to use for signature?
the customer wants an actual autograph
Mar 06, 2008 at 08:06 PM
Paul Krog
p.1 #6 · Which pen to use for signature?
You might try some of the paint pens that are available. Try this on a small print on the same paper and see what the results are. I have seen them in craft stores in many different colors. I suppose that adhesion is a big question.
Paul
Mar 06, 2008 at 08:13 PM
mdude85
p.1 #7 · Which pen to use for signature?
If the ink or the paper are not archival quality, then it won't really matter about the pen.
Mar 15, 2008 at 09:27 PM
RGS65
p.1 #8 · Which pen to use for signature?
I've had no problems with sharpies. They come in every color under the rainbow, including silver and gray. You can get fine points too.
Mar 15, 2008 at 09:44 PM
Timm
p.1 #9 · Which pen to use for signature?
Sharpies are anything but permanent. I'm looking at a museum-grade B&W print (the real kind) a friend signed for me with a Sharpie three years ago. The sig is now barely legible.
I use the Sakura Identi-Pen. It has a very fine point on one end and a larger point on the other. No problem with skipping on RC or glossy printer paper. They dry immediately, never run or bleed through, and seem to be about eternal in longevity. I'm not sure what colors are available, as I usually sign in black just outside the image area.
Pilot also makes a nice line of archival pens, which are available in metallic (real metal) pigments--I have one in silver and one in gold. They take a while to dry, but will last asa long as the metal dust in them--I guess the gold will last a while.
Mar 16, 2008 at 10:54 AM
mkweaver
p.1 #10 · Which pen to use for signature?
I use a "gold-writer" pen, gold or silver, or any other color foil, and sign my prints. I've had this "gold-writer pen" for 30 years, and am still using the same one! It's a bargain!
It works like a woodburner, plug it in, let it heat, then write over the foil to make the foil embed into the print. So far, prints I signed 30 years ago still have the signatures as fresh as when new.
Edited on Mar 17, 2008 at 09:22 AM
Mar 17, 2008 at 09:21 AM
KiboOst
p.1 #11 · Which pen to use for signature?
Sakura Pigma Micron are only available in black or color, is there same quality archival pen in white ? I would need a black one and a white one for different photos.
Mar 17, 2008 at 11:10 AM
