Wedding Resource List
Archive 2008 · Demb flash bracket question
Mike Mahoney
p.1 #1 · Demb flash bracket question
Does the bracket lay flat for storage?
Thanks,
Mike
Mar 05, 2008 at 10:59 AM
msack
p.1 #2 · Demb flash bracket question
Yes, it will flatten out quite nicely. I really like it.
Mike
Mar 05, 2008 at 11:19 AM
Mike Mahoney
p.1 #3 · Demb flash bracket question
Thanks Mike .. do you find enough room for your hand between the camera & bracket?
I've not had one in my hands but from the look of the photos on Joes website the bracket is on the same side as your hand, and you fit your hand between the camera body & the bracket?
Mar 05, 2008 at 11:36 AM
Mike C.
p.1 #4 · Demb flash bracket question
Mike, As your right hand only holds the camera body and fires the shutter, you will plenty of room. I leave mine on all 3 bodies, just put the flash and diffuser on when required.
Mike
Mar 05, 2008 at 12:38 PM
Mike Mahoney
p.1 #5 · Demb flash bracket question
Yes .. I've had a closer look at the photos and it seems the bracket is also slightly forward of the camera as well, so lots of room.
Thanks
Mar 05, 2008 at 12:41 PM
nicholasong
p.1 #6 · Demb flash bracket question
How about shooting in portrait? Do you have to wrap your hand around the bracket?
Nick
Mar 05, 2008 at 01:08 PM
Mike Mahoney
p.1 #7 · Demb flash bracket question
Nick
From the look of the photos on the Demb website your hand goes in between the bracket and the camera body.
Also the bracket appears to be slightly offset (toward the front) and that gives your hand some additional room.
Mar 05, 2008 at 01:27 PM
Joe Demb
p.1 #8 · Demb flash bracket question
http://www.dembflashproducts.com/bracket/
This page shows (me) doing verticals with both a regular shutter release and an optional shutter release on a Nikon F2.
Mar 05, 2008 at 04:01 PM
Mike C.
p.1 #9 · Demb flash bracket question
Nick, Shooting vertical is just the same as without the bracket, as you go from view to vertical you just turn the flash head, see photo or film here:
Mike
Mar 05, 2008 at 04:04 PM
Kiron Kid
p.1 #10 · Demb flash bracket question
Just returned from shooting a wedding in the Newport Aquarium. As I've said before, I'm no fan of flash brackets. But, there are times when they can be quite useful. For this wedding, I took my Demb bracket (newer model) out for it's maiden voyage. I found it very easy and intuative to use. I was able to hold my camera as I normally do, which makes it very easy and convenient to make camera or lens adjustments. With other brackets, it seemed that I was always somewhat at the mercy of the bracket design, and having to work around it. With the Demb bracket, I never found it to be inhibitive of my shooting style. I also like how well it's designed and built. It's quite compact and easy to store when not in use.
Kiron Kid (Russ)
Apr 14, 2008 at 02:50 PM
fotorelic
p.1 #11 · Demb flash bracket question
Anyone had any problems with the constant tension bolt loosening?
Apr 14, 2008 at 06:17 PM
Kiron Kid
p.1 #12 · Demb flash bracket question
Mine worked flawlessly. No problem at all.
Kiron Kid
Apr 14, 2008 at 08:47 PM
