Moderated by: guardian
FM Forums | Photo Illustration & Digital Art | Join Image Upload
gheller
Buy and Sell: On
p.1 #1 · KVM switch with Wacom Tablet
I suspect that many of your work here is done with a tablet, hence the reason for posting here.
From what I have done in research, it appears that the Wacom Intuos tablet cannot be used with a KVM switch.
My questions is...anyone get it to work? If so, may I ask how.
If not...anyone want it
thanks in advance
greg
Feb 17, 2008 at 02:56 AM
RodBarker
Image Upload: Off
p.1 #2 · KVM switch with Wacom Tablet
I believe it works through a USB KVM switch ,, are you trying to use a ps2 usb adapter ?
Rod
Feb 17, 2008 at 10:01 AM
gheller
Buy and Sell: On
p.1 #3 · KVM switch with Wacom Tablet
yes, my KVM is a PS2 version with PS2 -> USB adaptors. From what I read, the tablet has issues with all KVMs, but you think it will work with a USB KVM?
thanks
greg
Feb 17, 2008 at 06:05 PM
RodBarker
Image Upload: Off
p.1 #4 · KVM switch with Wacom Tablet
Greg I just quickly googled on reading your original post and found quite a few response's where it worked with a USB switch , I cant say for sure as I dont have one but it seems many have it working with a USB switch .
Rod
Feb 18, 2008 at 06:06 AM
cpurves
Image Upload: Off
p.1 #5 · KVM switch with Wacom Tablet
Greg:- are you using the switch to move from your mouse to the tablet?
I have my tablet and mouse plugged into two different usb ports and both work at the same time no need for a switch.
Cheers
Chris
Feb 18, 2008 at 04:43 PM
julief
Image Upload: Off
p.1 #6 · KVM switch with Wacom Tablet
Greg - I have my Wacom tablet on a USB KVM and it works seamlessly. I use the pen and tablet from all three of my PC's. The trick is to load the Wacom software on all the PC's that you want to use the tablet. I'm not so sure exactly what you're doing. It sounds like you're using adapters. My suggestion would be to go to a straight USB KVM. I don't think you're going to get it to work thru adapters.
Feb 18, 2008 at 10:35 PM
Lost password?
