Archive 2008 · Ghanaian Gold Mining
Matthew Palmer
p.1 #1 · Ghanaian Gold Mining
I'm a young photojournalist living in Ghana documenting human rights abuses in mining communities. Any comments or critiques would be very appreciated.
Thanks!
http://farm3.static.flickr.com/2283/2243653817_a64631eb3c.jpg
http://farm3.static.flickr.com/2118/2235005336_914fdb94d6.jpg
Matthew Palmer
Feb 07, 2008 at 04:32 AM
Scott Stoness
p.1 #2 · Ghanaian Gold Mining
Welcome.
Taking pictures for documentation reasons is different than I am used to - but let me give you comments on artistry anyway.
Both pictures are quite busy with the main subject too small. I think a lower closer perspective would be better so that the worker fills most of the frame. It would be better if you could see some expression on their faces. You have lots of items leaving the frame that distract. I think you have to get lower and zoom in more.
I suspect the making a better artistic picture will also make you message more powerful.
Feb 07, 2008 at 09:04 AM
Matthew Palmer
p.1 #3 · Ghanaian Gold Mining
Thanks for the ideas Scott. I chose those images because the most clearly showed the figure of the miners going in and out of the pit.
Do you prefer this one?
http://farm3.static.flickr.com/2309/2235007720_8c577306ef.jpg
thanks
Matthew
Feb 07, 2008 at 11:23 AM
sbeme
p.1 #4 · Ghanaian Gold Mining
Hi Matthew,
I agree with Scott's comments on the first two.
Third is better with tighter focus on the miners, capturing a connection between the two, and showing emergence from the mine. I think it needs a bit of exposure correction; looks a bit under-exposed. Could also benefit from just a bit of contrast bump and perhaps a bit of shadow recovery.
Happy to post a variation.
Of the first two, exposure is much better on the second, content is more engaging.
Feb 07, 2008 at 08:21 PM
Scott Stoness
p.1 #5 · Ghanaian Gold Mining
Last post is much better because it is closer in and more of their faces.
It still could be framed better - a bit lower to get rid of the left top tank and get the steps in showing where he is going. And it is a bit tight between foreground and the ledge for me.
I would have framed the top left just above his head meeting with the 2x4. That would have got more steps and more foreground.
Feb 08, 2008 at 09:06 AM
Matthew Palmer
p.1 #6 · Ghanaian Gold Mining
Thanks tonnes for the comments. I would have liked to get more face shots, but the miners were pretty against it given that what they're doing is illegal. It was a pretty stressful situation actually; noone seemed to like the camera being around. I completely agree with all of your ideas, and hopefully I'll be able to head out there again soon to get some better shots.
Edited on Feb 08, 2008 at 10:09 AM
Feb 08, 2008 at 10:05 AM
Bob Jarman
p.1 #7 · Ghanaian Gold Mining
Hello Mathew,
I would echo the comments of sbeme and Scott.
Does the publication source for your images have any bearing on what is permitted in post-processing?
Also, I assume you shot those images with a purpose in mind. As an uninformed viewer, I guess I'm asking if I should conclude the workers are being subjected to abuse through what they are doing or is there another conclusion I should take away from the images. Is there a message, or is the stage being set for something else?
Hope you can make sense of what I've asked...I probably have not posed the question very well.
Bob
Feb 08, 2008 at 02:18 PM
Jammy Straub
p.1 #8 · Ghanaian Gold Mining
I greatly prefer the third image.
I will say when you're shooting for a story or covering an event sometimes it's good to step back and include some of the surroundings in a photo to give the viewers a sense of the place and conditions.
It's commonly referred to as "Context", as in giving a photo context within the scope of a story.
For instance I can't tell where this little hole in the ground is at all or what that blue motor in the upper left hand corner of the frame is.
Nice work, can we see some more images from the area?
Feb 16, 2008 at 12:53 PM
