paulhodson Offline Image Upload: On
The colors look different but I feel that you are worrying about something which in a way does not make sense. You said that you want the unedited image to look like the original Raw - but the original Raw only looks like anything at all once it has been converted - and this is in fact editing. The default settings are only a starting point - and in fact you may find that the auto settings, especially if you are unsure what you are doing, might make a better starting point.
However, it should be possible to reset the defaults back to the original settings - in CS2 there is a drop down menu called "settings" in ACR which does this
