gfiksel Offline Image Upload: On
p.1 #13 · Upping resolution of JPGs for Printing | |
If you indeed have large size jpegs then don't worry about the resolution number. What matters is the size of the image in pixels. Just send it for printing and all you have to do is to specify the size of the print (in inches or cm). The printer driver will do all the necessary manipulations and adjustments.
If you really want to change the "resolution" (again, you don't have to) you can do it in ImageSize of Photoshop. Just DO NOT check the resample box (John E advise is wrong) and type a number that you want (e.g. 360). While you're doing it keep looking at the pixel dimensions of the image and document size in inches (that would be your print size).
The pixels dimensions should not change - that's exactly what you want. You don't want to change the number of pixels. On the other hand, the document, or the print size in inches, will change. This size should bigger, or at least not much less than the print size you want. But, unless you were shooting small jpges or you want to print a very large size you will be fine.
Edited on Dec 26, 2007 at 06:23 AM
