Archive 2007 · Scan settings for MF film
andylaiphoto
p.1 #1 · Scan settings for MF film
I am going to start scanning my MF shots from my Holga. If I intend to make prints about 10x10inches, what would be a good scan setting? DPI and target size?
I've never scanned film before.
Cheers.
Dec 21, 2007 at 01:33 PM
Steve Blagg
p.1 #2 · Scan settings for MF film
What are you scanning with?
I've had good results using an Epson Perfection4490,settings were:-
Image Type - 24 bit colour
Scanning Quality - Best
Resolution - 600 dpi
Target Size - Original
Scale - 200%
Unsharp Mask filter - On
Grain Reduction & Dust Removal - as required
Rendered about 20Mb file, plenty for your 10 x 10
Dec 22, 2007 at 09:57 AM
andylaiphoto
p.1 #3 · Scan settings for MF film
I have a V700. Thanks for the insight.
Dec 22, 2007 at 10:33 AM
andylaiphoto
p.1 #4 · Scan settings for MF film
Steve Blagg
p.1 #5 · Scan settings for MF film
Scale - 200%
tived
p.1 #6 · Scan settings for MF film
3200 dpi
16bit
get the colors as good as i can in the scanner software
usually don't do any noise reductions
the V700 does a really nice job and it is relatively fast
Henrik
Dec 26, 2007 at 09:46 PM
tived
p.1 #7 · Scan settings for MF film
I finish the image up in photoshop
Henrik
ps: you specify that you want it to be 10x10" today, in which you would probably need 3000 pixels in total across the 2 1/4 inch of the format, but I would still scan at higher resolution and make a multi purpose file, that I can use to upsize or down size depending on my need, but I only need to do the hard work once!!!! YMMV best of luck
Dec 26, 2007 at 09:49 PM
Duncan Staples
p.1 #8 · Scan settings for MF film
Steve/Henrik:
Are you using the Epson software or VueScan?
Duncan
Dec 27, 2007 at 04:58 AM
andylaiphoto
p.1 #9 · Scan settings for MF film
epson scan and silverfast are my two methods
Dec 27, 2007 at 12:38 PM
