Ashish Aleti Offline Image Upload: Off
p.1 #1 · F stops in relation to shutterspeed and aperture | |
I am new to photography and I found this topic when i was reading about how to use GND filter's.
its a topic about how to use a GND filter when shooting a landscape with a snowy mountain top and a foreground with a bed of flowers.
"Take a meter reading of the snow on the mountaintop. Remember to use a narrow-angle meter, such as your spot meter, as you want to meter the snow and only the snow. Your meter gives you the direct values of 1/125 sec. at f/16, but you know that this will render the snow as a medium tone. To make the snow a pure white, you must open up 2 stops to 1/125 sec. at f/8.
Now meter the foreground --the shadowed meadow. It's basically a medium toned area. There are some slightly lighter flowers and a few darker leaves, but it averages out to a medium value. Take a meter reading here using an overall metering pattern. The values read out as 1/60 sec. at f/2.8.
Now count how many stops difference there are between these two readings. Well, you slowed the shutter speed by one stop and you opened the aperture by three stops, for a total of four stops"
How is it that it is 1 stop between the shutter speeds? i really cant understand this
correct me if I am wrong, 2.8 X 3 is close to 8.0 is that how it is 3 stops difference between the apertures
thanks
Ashish
Edited on Dec 13, 2007 at 12:50 AM
