Joel Kern Offline Image Upload: Off
p.1 #4 · Shooting Below 32 degrees | |
Shooting in 9F temps should be fine. It's out of the camera's specs, but the camera shouldn't mind too much... it is, after all, a pro model. I've used Canon and Nikon cameras in single-digit temps on many occasions. The only things you need to worry about are the battery (first thing to be affected by colder temps) and the CF card (second thing to be affected... but with a worse effect). I switched to the Sandisk Extreme cards many years ago because they handle the cold really well. Before using those, though, I used to keep a CF card in my pants pocket so it would stay warm and swap it out with the one in the camera if and when the camera would error.
Just be sure your batteries are fully charged and understand that if your camera errors it probably just means the CF card is too cold to write to.
Edited on Dec 12, 2007 at 03:24 PM
