Archive 2007 · Canon 400mm f/5.6 + Extention Tubes
Allan Bruce
p.1 #1 · Canon 400mm f/5.6 + Extention Tubes
I am pretty sure I am going to be getting one of these as my next telephoto lens but I am mildly concerned about the minimum focus distance.
Can anybody comment on how the focussing is affected by a 12mm extension tube? I am interested in the new min and max focus distance.
(also if anybody can comment on any other extension tube length it would be useful too - I have the kenko set so have up to ~70mm of extension available).
Edited by Allan Bruce on Dec 07, 2007 at 09:02 AM GMT
Dec 06, 2007 at 10:32 AM
abqnmusa
p.1 #2 · Canon 400mm f/5.6 + Extention Tubes
you should be fine with your extension tubes. I have added 25mm + 12mm tubes and it brings in the focusing much closer. I have used it to focus on flowers & butterfly with that setup.
Dec 06, 2007 at 10:58 AM
jcw1982
p.1 #3 · Canon 400mm f/5.6 + Extention Tubes
There was just a thread on the nature and wildlife forum about using a 400 5.6 w/tubes for close up work 3 days ago. Might be worth checking out if you haven't seen it----looked like it worked pretty well!
Dec 06, 2007 at 11:24 AM
Allan Bruce
p.1 #4 · Canon 400mm f/5.6 + Extention Tubes
I just had a look at that thread but its not quite what I am after. I would like to know the approximate focal distances with extension tubes attached. The main reason that I visit a lot of local bird hides and the birds often get quite close ~1.5m away. I would like to add an extention tube to focus on these but when doing so I would like to know how far I still focus for further birds. I dont want to have to be adding/removing the extention tube every 2 minutes - I doubt the birds would sit still long enough for that anyway!
Thanks
Allan
Dec 07, 2007 at 04:01 AM
Gertjan
p.1 #5 · Canon 400mm f/5.6 + Extention Tubes
From the Canon Literature:
EF400mm f/5.6L USM with 12mm extender:
magnification: 0.16~0.03 x
Focusing Distances: 2.893 - 13.449 meter
Working Distances: 2.583 - 13.138 meter
EF400mm f/5.6L USM with 25mm extender:
magnification: 0.21~0.07 x
Focusing Distances: 2.460 - 6.610 meter
Working Distances: 2.145 - 6.295 meter
It seems to me that with your set of extension tubes you can get any working distance you would like to have.
Regards, Gertjan.
Dec 07, 2007 at 04:38 AM
Medlock44
p.1 #6 · Canon 400mm f/5.6 + Extention Tubes
Just tested the 12mm ext tube with 400mm lens mounted on 40D
Min focus 4' app and max 30' app
Hope this helps
Dec 07, 2007 at 04:48 AM
kjetils
p.1 #7 · Canon 400mm f/5.6 + Extention Tubes
Hi
The 400 works fine with extension tubes. But for close-up work I would really prefer the 300f4IS with a mfd of 1.5m
K
Dec 07, 2007 at 08:30 AM
Stumped
p.1 #8 · Canon 400mm f/5.6 + Extention Tubes
My first lens was the 400 f5.6. When I started using tubes I ran into the very problem you describe. I bought a 300 f4 & problem solved. The only time I need tubes with this setup is shooting very small dragon flies. I have a 1.4 extender glued to the 300 when shooting birds & bugs.
TW
Edited by Stumped on Dec 07, 2007 at 03:22 PM GMT
Dec 07, 2007 at 09:11 AM
EOS20
p.1 #9 · Canon 400mm f/5.6 + Extention Tubes
I find the 100-400 works great for close up work. Even without extenders you can get nice and close. I haven't tried using the extenders yet, But might get a set soon to get even closer!
Dec 07, 2007 at 09:15 AM
ward1066
p.1 #10 · Canon 400mm f/5.6 + Extention Tubes
Out of curiosity I took my Kenko 25mm tube and attached my canon 1.4 TC on my 400 5.6. One thing I noticed is you will really need some really good light. This shot was taken outdoors overcast handheld ISO 6400 and the shutter speed was only 1/250 f8. Live view is really nice for close up focus, just set you lens at min focus distance and move it in and out. Focus distance was about 5-6 feet.
http://upload.pbase.com/image/90004972/original.jpg
Dec 07, 2007 at 10:03 AM
Pixel Perfect
p.1 #11 · Canon 400mm f/5.6 + Extention Tubes
Here's a couple of 400L + 36mm ext. shots:
http://www.dphoto.us/forumphotos/data/1062/JS6R5853.jpg
http://www.dphoto.us/forumphotos/data/1256/JS6R5838.jpg
Approximately if you add 12mm extension to the 400L which has a MFD of 3.5m the new MFD will be 2.9m. Not sure of the maximum focus distance though.
Dec 08, 2007 at 02:10 AM
