gzasinets Offline Image Upload: Off
p.1 #6 · Color Profile Questions | |
brad_s wrote:
gzasinets wrote:
Ray, just keep your files in sRGB or AdobeRGB or any other color space - do not convert your pictures to costco printer profiles. They give you their profiles for softproofing only. You probably need to calibrate and profile your screen so you can trust colors you see. Maybe try mpix for printing.
Sorry, Gzas, but this is incorrect. The printers at Costco do not embed their own color profile at the time of printing like mpix or WHCC nor can it read embedded profiles attached to photos. Their printers require the actual print to be converted to the color profile so it does nothing but just prints only as it sees it. So Ray, you're better off converting a copy of your print to the costco profile and dumping it after you've sent it as you can not unconvert or reconvert a profile after you've saved and closed it in photoshop. Just delete it afterward because the profiles get updated and all these files will have an outdated profile. As an aside I have about 1000 pictures on my costco account that have a profile from last year and they don't work with their newer profile. ...and the 500 or so I have of their new profile will be obsolete soon because they are going to upgrade to a new Noritsu 4xxx printer that is going to have a different profile.
Ray, your screen should first be calibrated and you want to do all your work in a standardized color space e.g. sRGB or the other two available. When you convert the print to the costco color profile it is certainly going to look different because the profile is intended to respond to the hues of the paper and ink used by them but when actually printed it should look like how your photo appeared on your screen in sRGB not how it looked after you convert to profiles. For example, I'm looking at a picture now that I just converted to a costco profile and it now has a strong green hue - these changes are normal as this is technically for the printer to see and not for our eyes. If you would like to simulate what the print is going to look like on paper then you would do a soft proof where the monitor simulates the conditions of printed paper with the profile.
The other thing about missing the pop - i'm not sure exactly what you mean but print media in general doesn't pop like it does on the screen. Yes, many printed pictures can really pop and jump out of the page, but in general paper is not going to be as vibrant as a back lit screen.
good luck.
Brad, I just described the way it should be and that's how normal labs do it. If costco doesn't even recognize embedded profiles than using there service is absolutely useless IMHO. I never used them as a matter of fact and never will. Converting to output profile is through the ass color management.
Edited on Dec 06, 2007 at 06:38 AM
