Archive 2007 · 200mm F2 + 1.4x ???
Benjamin Munn
p.1 #1 · 200mm F2 + 1.4x ???
For those of you that have used this combination, how does it stack up compared to the 300mm F2.8?
I am looking to start building my system and have conisdred going with the 200mm F2 + eventually a 400mm F2.8.
If anyone has any samples shot wide open, I would appreciate it.
Thanks.
Nov 26, 2007 at 05:03 PM
Outoffilm
p.1 #2 · 200mm F2 + 1.4x ???
I use this combo ( 200mm f2 + TC14EII ) all the time on a D2Hs and it works wonderfully . I can't really even tell if the TC was on or off ( no IQ loss at all ) .
However I cannot compare it to a 300mm f2.8 simply because I do not own that lens . It did compare it to a 300mm f4 AFs and a 70-200 VR and it is WAY better .
On my copies , the 200mm f2 with TC shot wide open is better than the 70-200VR shot at f4 with no TC .
Nov 26, 2007 at 05:24 PM
Zachs
p.1 #3 · 200mm F2 + 1.4x ???
You can probably stick a peice of frosted glass in front of that lens and it'll still be sharper than most of lenses wide open
From what I've seen on here in teh past its very very sharp, but I doubt it will be able to compete with a pristine 300 2.8 for speed and sharpness wide open.
Nov 26, 2007 at 05:26 PM
George61d
p.1 #4 · 200mm F2 + 1.4x ???
I have a slightly different experience to outoffilm. without the TC the 200/2 is very sharp at f2. Stick the tc1.4 on it and you have to stop down to F4 to get back to the same level of sharpness - all other aspects of IQ are fine with the TC1.4 on board. I have no idea about the 300/2.8 as I have not shot with that lens
Nov 26, 2007 at 05:38 PM
sleightofhand
p.1 #5 · 200mm F2 + 1.4x ???
I tested this out last year some time and against other lenses like the 70-200vr and the 200-400vr to see the differences... From what I can gather it's very close..as you know - if you stop down a lense - it will look a tad bit sharper compared to one that's wide open. I got those results with the 1.4x TC on the 200vr. Here's a few un-scientific shots on a cloudy/sunny day...
200vr lens + 1.4x teleconverter f2.8 at 280mm 100% crop:
300vr lens f2.8 100% crop:
Nov 28, 2007 at 05:55 AM
Stan Otokpa
p.1 #6 · 200mm F2 + 1.4x ???
Looks like the 200 f/2 and TC is the winner!
Nov 28, 2007 at 06:01 AM
Pixel Perfect
p.1 #7 · 200mm F2 + 1.4x ???
That must be a bad 300 or misfocused.
Nov 28, 2007 at 02:04 PM
Creative Edge
p.1 #8 · 200mm F2 + 1.4x ???
The 200 f2 is an amazing piece of glass... I use mine with a 1.7 tc wide open
and it compared to my 300 2.8 vr at the same aperture... 3.5...
image quality was the same...
sold the 300 2.8.... now I have the 400 2.8 and 200 f2... if I need a 300... the 200 takes over.... very fast to focus, focus is precise...IQ is second to none..
Nov 28, 2007 at 03:30 PM
Benjamin Munn
p.1 #9 · 200mm F2 + 1.4x ???
Thanks for the information everyone. It looks like I will grab a 400mm F2.8 and then a 200mm F2. Should be a nice combo for most field sports when adding in a 1.4x.
Nov 28, 2007 at 03:36 PM
