Archive 2007 · Scrub Jay "pop"
Brian Kersey
p.1 #1 · Scrub Jay "pop"
I've been working on giving my pictures more "pop". This is my picture that I think I did a good job on. What do you guys think?
Photo Sharing and Video Hosting at Photobucket
How do you guys add that "pop" factor to your photos in PS?
Nov 24, 2007 at 11:58 PM
paulhodson
p.1 #2 · Scrub Jay "pop"
Levels alteration (shadow only), USM at 10,200,0 on duplicate layer set to luminosity, sharpened. Brightened a little with curves (or centre slider in levels)
PM me if you need more info
Nov 25, 2007 at 02:38 AM
Wayne Cardwell
p.1 #3 · Scrub Jay "pop"
Brian,
From your photos exif data and your profile I'm going to guess that you used your 100-400L lens at close to 400mm. A 1/320 shutter speed even with IS is a little slow at that mm, coupled with the 800 ISO left your image a little soft. With a 1D and an L lens your pictures should have plenty of pop. You need more shutter speed and a lower ISO for the best results.
WC
Camera Model
Canon EOS-1D Mark II
Tv( Shutter Speed )
1/320
Av( Aperture Value )
5.6
ISO Speed
800
Nov 25, 2007 at 01:16 PM
Scott Stoness
p.1 #4 · Scrub Jay "pop"
The picture is soft. 1/320, 400mm, iso800. f5.6 gives you about 3-4 inches of depth.
You have 2 problems - too slow shutter for moving object and very tight depth. You can solve by going up to iso1600 to get faster shutter or f8, but not both given the low light. I would choose the faster shutter and iso1600.
See below:
I did my normal.
Cropped in closer
Set the levels to move the bars in to histogram
Adjusted levels to bring out details in feathers
Adjusted saturation
Then did saturation at 0,0.3, 204
Not sure if it is improved but I like to try.
Nov 25, 2007 at 03:34 PM
Jim Schemel
p.1 #5 · Scrub Jay "pop"
Brian,
Here is my try at it.If you have DPP just sharpen the jpeg( dont be afraid to push it a bit) adjust contrast and increase saturation.
-Jim
Image Hosted by ImageShack.us
Nov 25, 2007 at 05:09 PM
Wayne Cardwell
p.1 #6 · Scrub Jay "pop"
See below:
I did my normal.
Cropped in closer
Adjusted saturation
Scott,
Your correct on the DOF, I figure he was 25-30ft away. But the f8 will give a slower shutter and the 1600 would be pretty graining. The f5.6 is wide open on 100-400L at 400mm, he could back out on the zoom to get some apeture back may be a f5 -4.8 and then crop in.
WC
Nov 25, 2007 at 05:53 PM
Steve Spencer
p.1 #7 · Scrub Jay "pop"
Hi Brian,
Here is my attempt. I just used my standard workflow. I bring it into aperture for tweaking exposure, saturation, contrast, white balance, and levels. Then I bring it into CS3 for cloining, layers, and sharpening. In this image I did minor tweaks on exposure and white balance (a little more exposure a tiny bit cooler white balance), I add a moderate amount of saturation and contrast and did nothing to levels. Then in CS3 I did a fair bit of cloning to minimize distractions from the image and then apply a 300/.3/0 unsharp mask command to sharpen the image. Here is the result:
http://www.arts.uwaterloo.ca/~sspencer/pictures/ScrubJayDinner3copy.jpg
I hope this helps.
Steve S.
Nov 25, 2007 at 07:26 PM
Brian Kersey
p.1 #8 · Scrub Jay "pop"
Thanks for everyone's help. I'll try to "re-vamp" the photo myself and repost it
Nov 25, 2007 at 09:42 PM
