Scott Stoness Offline Image Upload: On
ssuresh98
To your question - what is wrong? - I think mostly that there was too much air pollution
You should post your picture you are unhappy with for comment. Because your problem could be different than the problems with this post. ie you might be shooting with too high an aperature.
Here are some generic tips:
1) This picture likely would have been better with a circular polarizer to get the details in the clouds
2) Use a tripod cranked down (so it does not vibrate as much and does not catch the wind), use a remote shutter release (to avoid vibration) and turn off the image stabilizer when on tripod (causes seeking ==>noise). If you want to go even further set the mirror to stay up.
3) Check the exposure on histogram and increase decrease to get no clipping of histogram
4) Check for blinking areas in histogram view and reduce exposure to eliminate
5) Shoot at f8 - usually the sharpest spot on lens, beyond f8 defraction causes distortion. Don't go beyond f11 on 1.6 (20d, rebel) or f16 on 1.0x camera (5d) because of defraction. If you are using a wide angle, f8 is likely focused from 10' to infinity. Focus on infinity since distortion is likely to more noticable on buildings (which require detail) than foreground
6) Use a nd graduated filter to reduce the exposure of the sky and allow proper exposure everywhere. Alternately use autobracketing and hdr but this is lots of work.
7) Ultimately, I am not sure this particular photo can be fixed to the point that you would be happy to print it because it was just a bad day/hour for shooting with haze. On these kind of days shoot macro or portrait.
8) There are two different dimensions to lighting - specular vs diffused, and angle. Direct sun light (here) flattens the image. Diffused (clouding day) gives you a less flattened image. Shooting this picture early in the morning would really improve it. Direct light flattens the picture. Side lighting brings out the details. Again early morning would improve the lighting in this picture. The other kind of light is backlit where the sun is behind the building that gives a silhouet but this is not possible from this angle.
Edited on Nov 28, 2007 at 07:32 AM
