Mike Ganz Offline Image Upload: On
I wouldn't recommend round GND filters (unless you really, really want round filters). The demarcation line is generally smack in the middle of the filter, which doesn't allow you any wiggle room if you need to make an adjustment to suit your composition. For GND's, you'd be better off with square or rectangular filters from Hitech or Lee. There's also Singh Ray, but at a considerably higher cost. The square and rectangular filters can be slid up or down within the holder to fine-tune the placement of the demarcation line (not so with round ones).
On the 2filter.com homepage, click on the catalog link on the left hand side of the page. On the next page, scroll down the right hand side...there you'll see links for Hitech, Lee, and Cokin brand filters. They have some packages available for each manufacturer (IIRC). For what its worth, I'm using the Lee filter holder with the normal and wide abgle adapter rings, along with Hitech GND's. I originally tried the Cokin Z-Pro holder, but didn't care much for the design. The Lee holder is only a few dollars more, but well worth it IMO.
Just noticed that your thread title refers to ND filters, but the thread itself mentions GND filters. Just in case you did mean 'ND', they're also available in square and rectangular format from the names mentioned above. You can also get them in round style...I bought several round B+W ND's from this site: Filter link
To avoid stacking multiple densities of ND filters, another option is the Singh Ray Vario ND filter...its a single round variable ND filter that will give you anywhere from 2 to 8 stops in light reduction. Its only in two sizes (as far as I know), with 77mm being one of them. Its a bit pricey, though (~$350)...but then again, what isn't.
Edited on Nov 15, 2007 at 07:16 PM
