MSC Offline Image Upload: On
sjms wrote:
Shane Canfield wrote:
I don't think there any real difference. Personally I like Kirk brackets because they seem to use less metal, but this is not a product that requires much in the way of complicated design.
Now I will say this, the RRS bracket for the Mk3 is not well designed. I will sell mine if you want it...just have not gotten around to putting it on the B&S board. The vertical section of the bracket sticks WAY out behind the back of the camera and ruins holding the camera. Now I do not yet have the Kirk but in looking carefully at the website, it seems to be much more flush.
As for other products, this is not one that matters. You can mix and match. There seems to be an issue with RRS level clamps...which you read about on their website, no need to repeat it here. I personally have Wimberley, Kirk and RRS products and have no problems switching any of them out. But then again I don't like lever clamps.
you will find the the location of the side plate is approx a little over a 0.25" further back so you have access to the most used i/o ports on the camera when it is flat against the camera. as a generality i don't handle the camera with my left hand as much as i do the lens. not an issue.
as to the less metal statement well weight wise there again within a gram or two. so much for that.
see i'll accept the minor compromises so that i only need 1 plate to do the job
The bracket sticks way out behind the camera...no other backet I have ever used does this and IMO, it is a poor design. I have not measured it but really don't care how far it is...it feels terrible in the hand. For as much money as RRS charges, I expect more.
Edited on Nov 13, 2007 at 07:47 PM
