p150 Offline Upload & Sell: Off
p.1 #9 · 56 vs 30 inch moonunit | |
cgardner wrote:
The moon unit is designed to be used with a ring light. If a ring light is around the lens it doesn't create shadows the camera can see. That creates a visual riddle similar to the one which asks, "If a tree falls in the forest and there is nobody there to hear it, does it make a sound?" If a light doesn't create any shadows the camera can see, do you really need a huge diffuser on it?
Chuck Gardner
Chuck, much of your writing on this forum has to do with perception. Keeping with that spirit, let's take a tongue-in-cheek look at your paragraph above.
Sentence #1) The reader's perception right off the bat is that you are talking about the moon unit and ring light separately, "The MOON UNIT is designed to be used with a RING LIGHT". This sets the scene for the reader to follow through the rest of the statements.
Sentence #2) "If a RING LIGHT (here already perceived to be referring to the ring light only) is around the lens it doesn't create shadows the camera can see." This statement is not only untrue*, but also plants information in the reader's mind that will be used as a pivoting point in the next line.
Sentence #3) Here's the lead-in: "That creates a visual riddle similar to the one which asks, "If a tree falls in the forest and there is nobody there to hear it, does it make a sound?"" Chuck, you've gone existential on us! You speak often about leading a viewer's eye through a photo, in this case you seem to lead the reader to draw an analogy between the tree scenario and the use of a ring light along the lines of, 'If a ring light creates a shadow, and the camera can't see it... does it need to be softened?'.
Sentence #4) Here you spell out your analogy for the daft out there who might not have gotten it the first time around. "If a light (still in the readers mind as without the moon unit) doesn't create any shadows the camera can see, do you really need a huge diffuser on it?" Okay, this brings it all home for the reader, who is now perceiving this whole paragraph as you questioning the need for a moon unit at all.
Take armed with this information, the reader then perceives your next reply to Mr. Buff, "My statement was in the context of the practical differences between the two sizes of moon units. You are certainly correct that there will be a significant difference between direct ring light and a ring light with a soft box attached, just as there would be in comparison of direct flash vs any softbox." as you doing some major back-peddling.
* On the point of a ring light being around the lens, and thus creating no shadows seen by the camera: You know as well as I do that this isn't the case. The only way to get truly shadowless lighting from a hard light source is to have the light coming from a point directly at the center of the lens. Any variation from that point will result in some type of shadow visible to the camera, however small it may be. Distance to subject and distance from subject to background will determine the angles involved and how much shadow is visible. The flash tube is two or three inches away from the lens, and any point on the flash tube will create an opposing shadow. This is why one of the tell-tale signs of a direct ring flash can be a thin halo of shadow surrounding the subject on all sides. Now, with a broader light source such as the moon unit, the angle has changed, or rather, the light is coming from a number of angles allowing some angles to fill the shadows of light coming from other angles (whew, that's a lot of angles!). We have all seen how that works from your own diagrams (you know, the yellow ones with the little blue light rays being parallel, then not).
Anyway, I'm just poking some fun. Maybe I'm just in an argumentative mood. At any rate, I mean no harm and appreciate your contribution to this forum. Please feel free to completely blast me out of the water!
- Jeff
