Kalalika Offline Image Upload: Off
p.1 #9 · Photoshop to fit the theme | |
Sheila wrote:
I, like others, created their image using different means and areas of creativity.
I'm not bashing anyone's creativity. I enjoy Photoshop just as much as the next fella but this is a photography based site. There's a ton of websites out there for competition, honing, and showing off your creativity with Photoshop.
TRENTPULL wrote:
I believe you make a very good point about creativity being the prime driver of the assignment. Perhaps the unclear part of the instructions is just what is the prime objective - creativity, good shooting composition, PP skills, or what?
So, I maintain that it would be desireable to have a clear statement of the objective for the assignments in the instructions.
Trent
copied from Rules
Montage techniques are allowed but should be functional and kept to a minimum. Your entries for the monthly assignment should highlight your photographic skills, not your software knowledge.
Seems fairly clear to me but there is a large grey area that could be better defined.
EXAMPLE:
You may:
-use any feature of your camera while photographing your entry
-crop, rotate and resize your entry.
-clone out incidental power lines, twigs, dust specks, stray hairs, and similar minor imperfections.
-apply filters, effects, dodge & burn, and other tools to all or part of your entry, but NO new shapes or features may be created in the process.
-saturate, desaturate or change the colors of your entry or any existing object within it.
-use layers, layer masks, and alternative layer modes.
-use RAW conversion software.
-overlay two copies of the same original file and process them differently to enhance dynamic range.
-use software to correct perspective, lens defects, or minor misalignments.
You may not:
-use ANY editing tool to move, remove or duplicate any element of your photograph that would change a typical viewer’s description of the photograph
-use ANY editing tool to create new image area, objects or features (such as lens flare or motion) that didn’t already exist in your original capture.
-add graphics, clip art, computer-rendered images or parts of other photographs to your entry during editing.
-use distortions to create new effects or radically alter objects.
-add a border
Look people my only problem here is that it's not a photographic challenge to take a photo and edit it to fit the current theme. Aren't we getting away from the intention of the weekly/monthly assignments if we've spent more time in Photoshop than on the original capture itself?
Edited on Nov 01, 2007 at 12:55 PM
