Conner999 Offline Dedicated FM Upload & Sell: On
p.1 #7 · 4 Zeiss Contax lenses on 1ds | |
Unless you are using some specific wide-angle Cz lenses, lenses of that FL on the 1Ds will not be an issue.
www.pebbleplace.com has a leica and CZ database showing user reports of issues with lenses and EOS mirrors. Unless it staes a clear 'No', the lens will likely fit - unless you have a 5D. With it's larger mirror, copies can have issues. That being said, I use a number shorter FL CZ lenses on my 5D that are rated 'iffy' with no issues. The same lenses were used by me on a 1Ds Mk and Mk2 with zero issues.
On some you may have to trim the 'shark fin' (see pebbleplace) to avoid marking the inside of the mirror box (not the mirror itself).
It takes 15 minutes with a dremel and is painless. In my mind there is no sense creating black dust inside the mirror box on your DSLR to keep a bread & butter lens 'mint'. Most people buying CZ lenses these days are using them on EOS slrs anyway, so....
None of the lenses in question are collector items (e.g. 21/2.8) , so it shouldn't be an issue.
AE or MM (green F22 or F16 marker) matters not a bit re: using them on an EOS body, but they do sell for more in the used market vs. the optically indentical AE versions.
The 135 is considered a steal, the 100/2.8 awesome, the 100/2 one of the best portrait lenses, the 180 has mixed reviews. The general consensus being that the Nikon 180/2.8 is a far better deal for roughly the same or less money. The 135/2 reviews are mixed - check out
http://www.fredmiranda.com/forum/topic2/237992/0#1966417
Enjoy the shopping.
