Lotusm50 Offline Dedicated FM Upload & Sell: Off
p.1 #17 · Pocketable Film camera with good quality (Alternative to PnS) | |
foges wrote:
Thanks for all the replies guys. I like the Rollei 35 the best and it seems you can get it quite cheap, the Olympus XA looks quite big and plasticy. I however just realized that my parents have a Leica Minilux that they are not using, its still kinda big though, but ill probably just use that and instead i can save up my money for something else. Like to buy an M series leica (rico's post got me thinking).
How big is that M4 actually? because of the angle of the photgraph it seems that it isnt much higher than the T3, but im not quite sure. Do the M series have light metering do you need a separate device? and how much do M4's usually go for?
The thing you should be aware about the Rollei 35 is that it is pure manual focusing, with no focus assistance at all. It is pure scale (i.e., guess) focus. Also there is no parallax compensation in the viewfinder. If you do look for one of these, get one with the 40mm f2,8 Sonnar lens (stay away from the Triotar)
If you care considering a Leica M, think about a Leica (or Minolta) CL, same lens mount in a more compact body (cheaper, too). Probably somewhere between a Minilux and an M6 in size. The Minilux your parents have is probably worth a try to see if you really need something smaller, like the T3. The Leica CM is, essentially, a very nice recent re-design of the Minilux (but is expensive).
If you want smaller than the Minilux, then I only half agree with Richard's choice:
brainiac wrote:
Contax T3 (in black) for 35mm
Fuji DL Super Mini (not the zoom version) for 28mm
I concur completely with the Contax T3 if you want a 35mm fixed lens. However, if you want a wider 28mm fixed lens, it really is hard to beat the Ricoh GR1s (or the updated GR1v). The lens is outstanding (you could even buy the same lens separately in a Leica M mount), the body truly pocketable with sufficient exposure control and focus options that it will do what you want it to do. Comes with a lens hood and you can even get filters for it. Here is an old sample image from several years ago (taken handheld with 400 ISO print film -- Portra 400VC). There is lots of detail in this negative:
