Archive 2007 · 5D exposure comp question
John Power
p.1 #1 · 5D exposure comp question
I have made the switch back to the 5D since the sun has set (temporarily) on my need for a 1 series camera. It seems to me that there is a way to prevent accidental EC change with the QC dial via a custom setting but I can't seem to find the answer in the manual I have downloaded. With the N you could map it to a different button so as to avoid unintended EC changes.
Am I imagining things of is it possible?
(I will be interested to see how the 5D pairs with my 85 1.2 II)
Thanks
Aug 18, 2007 at 03:11 PM
p.1 #2 · 5D exposure comp question
Well, the way I do it is to disable the QC dial when not actively changing exposure comp by putting the on switch to the first ON position. You may already know about this, but I'm not familiar with the 1D-series on switch, so it may be different. I'm sure your 85/1.2 will be fantastic on the 5D.
Aug 18, 2007 at 03:31 PM
Alan321
p.1 #3 · 5D exposure comp question
Jim, I'm sure that your suggestion will work for the 5D but the 1D-series bodies separate the on-off switch from the Quick Control dial switch, plus they have a personal function to prevent the QC dial being used on its own to affect exposure control. Tweakability is one of the benefits of going to the higher models in the Canon range.
- Alan
Aug 18, 2007 at 05:22 PM
John Power
p.1 #4 · 5D exposure comp question
That's what I was looking for on the 5D. I want to switch EC off to another button.
Aug 18, 2007 at 09:30 PM
Alan321
p.1 #5 · 5D exposure comp question
John, you're out of luck. The 5D is basically a 20D with bigger sensor and better AF, but no more customisations. It lacks personal functions and there is no custoim function or switch to do what you want. Plus the manual on page 92 indicates that using the power switch to disable the QC dial is the only way to prevent accidental application of exposure compensation.
Now if you'd paid three times as much to get a 1Ds2 then you wouldn't have this problem
- Alan
Aug 19, 2007 at 02:55 AM
Gochugogi
p.1 #6 · 5D exposure comp question
A CF to swap EC from QCD to main input dial was common on film EOS. It's odd to be missing from a camera like the 5D.
Aug 19, 2007 at 02:56 AM
Alan321
p.1 #7 · 5D exposure comp question
Canon like to dumb down the cheaper models to give the dearer models an edge. They wouldn't want to undermine the 1Ds2 sales too much with a fancy 5D.
Aug 19, 2007 at 10:23 AM
John Power
p.1 #8 · 5D exposure comp question
Too bad because I could not see a perceptible difference in the images from my old 1DSMKII and my previous 5D. That was one of the main reasons I sold the 1DSMKII.
Aug 19, 2007 at 01:30 PM
