ericvgill Offline Upload & Sell: Off
p.1 #7 · [MOVED] Using nikkor PC lenses on 5D | |
There are a number of choices, and I find the axiom of paying for what you get applies.
On the high end, the Novoflex makes the best build, period. Ultra-thin and fits like a glove, with no play. I've had problems with cheap adapters with noticeable slop after the lens is mounted (mainly bad corners in images). It has six screws in it's mounting, and infinity focuses at the infinity mark (I think a couple of the better built ones do so, but this is the only one I've tried that does). It's also $220+ USD.
Cameraquest is close, coming in at around $175. Opinion of it is high, but I've never used one.
The only models with AF confirmation seem to be the Hong Kong knockoffs, which unfortunately usually have the slop I mentioned above. They are, however, cheap enough it might be worth experimenting with.
This thread over in Alternative Systems is much more in-depth:
http://www.fredmiranda.com/forum/topic/556421/0
