wpman Online Image Upload: Off
p.1 #2 · 70-200 2.8 IS Underexposing | |
The only thing I can think of is some sort of iris problem. Underexposure is cause by one of two things--Too small an f-stop or too fast a shutter setting. Something is not allowing an adequate amount of light to hit the sensor, thus producing an underexposed photo.
The lens reacts to whatever the camera tells it to do.. If you use the Av mode, you set the f-stop on the camera and the signal is sent to the lens.
Because you say you are having problems with just the 70-200, it might be an iris problem, causing it to close down too much or it might be dirty contacts on the lens. Try some different exposure modes after wiping the contacts..That might help.
